Old 05-11-2001, 03:46 AM
stevegalante stevegalante is offline
Default New disks added, old disks audio files not loaded
Mac G3/300 384M RAM Mac OS 9.04 Atto Dual SCSI, PT 5.1. I've always worked with system disk (4G) + a backup HD (Cheetah 4G) on SCSI Bus 2, and 3x Cheetah 9G (used for normal PT sessions) on SCSI Bus 1. Now I've added 3x IBM 18G 10K. If I put them on SCSI Bus 2 (together with system HD and backup HD) no problem, if I switch the two systems, i.e. IBMs on SCSI Bus 1 and Cheetahs on SCSI Bus 2 when I open a PT session it doesn't locate the files, but strangely doesn't ask me where they are with the classic dialong, it just hangs on the window 'Locating audio files...' and I have to restart everything. Why ? (Obviously no SCSI ID conflicts)
www.downinhollywood.com
http://www.stevegalante.com
Old 05-12-2001, 12:43 AM
Default Re: New disks added, old disks audio files not loaded
Anything ? Anyone ?
Old 05-14-2001, 10:28 AM
NinjaBob NinjaBob is offline
This sounds like a termination problem. Make sure you have active termination on your SCSI chains. Also, make sure the drives themselves are not internally terminated. One last thing to check is that your SCSI cables are ok. Good luck.
PS. One question tho...why is your system drive on one of the SCSI busses on your ATTO card? Shouldn't it be on the IDE bus inside the computer?
Ninja Bob
Hothead
NYC
Ninja Bob
Hothead
NYC
Old 05-14-2001, 10:58 AM
Thank you ninjabob, I'll check the terminations, the cables are of the best possible quality. When I ordered my G3 I also ordered a Cheetah 4.5G SCSI drive, and (I don't know why) they gave me a SCSI HD as system drive and put both on the same SCSI bus.
Workspace has No Files & Hard Disks Listed Justinjsaley Pro Tools 10 0 07-02-2013 11:32 PM
setting "scratch" disks for audio and waveform data? nelsonmay Pro Tools 10 4 05-23-2013 10:19 AM
about to buy disks... Londoner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-29-2009 03:47 AM
dae can't get audio from the disks-error 9073 hirise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2004 10:02 PM
will I get pt5 disks? rich morpurgo Pro Tools TDM Systems (Mac) 1 01-06-2000 02:58 PM
