Old 09-18-2005, 03:29 PM
Joss Joss is offline
Default DigiBase problem with Bwav files
Hi all,
I will work on PTools 6.9 on MacOsX to do some sound design on a film. The problem is that may all SFX libary is Bwav format with description filled in the metadatas and files named as ie "EVL-01_01.wav". I've tried to load my sounds in the digibase, and all metatdata's are read in the Digibase Finder ( File Comments fields filled with good metadatas ... no problem for this). The problem is situated when I do a search in the digibase. I search in the "File Comments" for a word ( " forest" for example ) and the probleme is that the results displayed in the "results" window, have a "?" inside the "File Comments" field instead of the right description read just above. The weird thing is that good files has been found (for the search " forest" that's the good forest files the search engine found)
Is someone got an idea to solve that problem or is it a real known / unknown bug in the digibase
Thanks in advance ...
Jocelyn
Old 09-19-2005, 10:21 AM
DigiTechSupt's Avatar
Default Re: DigiBase problem with Bwav files
You should probably try trashing your database files to see if that fixes the problem.
Avid Audio Tech Support
Support FAQ
HTML code is On
App to create Bwav Poly files? Tim R. Pro Tools TDM Systems (Mac) 21 01-18-2013 09:35 AM
poly / mono bwav meta data problem markuse Post - Surround - Video 2 03-24-2011 06:17 AM
Audio files dragged in from DigiBase SZE Post - Surround - Video 6 08-21-2009 09:30 AM
PT7.3 Digibase Pro Catalog files message... beggehorn Pro Tools TDM Systems (Win) 5 08-19-2008 12:32 PM
Digibase Pro Catalog Files can't be converted... kazoo Post - Surround - Video 6 02-07-2008 02:06 AM
