ProTools 7.4 crashes when trying to import mp3
I've been having to use a 3rd party program (Nero) to convert mp3 files to .wav on files that I'd like to use in my sessions. If I try to import directly (import audio), PT crashes as soon as I click on the file and just knocks me out of the program. Earlier versions I never had this issue. I do own the mp3 option - which I just purchased thinking that would help - but no luck. I can export and bounce to mp3 but I cant import without the crashing.. Any ideas??? Thanks!
Re: ProTools 7.4 crashes when trying to import mp3
Check on what version of Quicktime is installed on your system.
(You can see the version listed in add/remove programs, find Quicktime and click it for more support info) If its an older version like 6.5.2.. uninstall it, download and install a newer version like 7.2 or 7.3 Hope that helps.
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
AWESOME, thanks! Un-installed QT and now it's all good. Outside of doing quicktime movies within PT, what else would be the reason, if any. for having QT installed on a PT system? Is it needed for converting Mac PT sessions on PC for their SD2 files - or is that handled straight thru PT anyway? I'm downloading the newest player for now but won't install until I run into some snag where PT might need QT. Thanks again for the help!!
thanks guys, this has also helped me! same problem. really appreciate the insight. MC
thax a lot guyz! i fixed that issue installing Quick Time 7.2
Mac Crashes after Quicktime Import | Freemason | Pro Tools M-Powered (Mac) | 1 | 06-02-2009 10:31 AM |
WinXP AVOption V10 AAF import , ProTools crashes. | audioposttvtwono | Post - Surround - Video | 1 | 03-04-2005 03:06 AM |
OMF Import crashes | Randy Garmon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-28-2004 02:29 PM |
OMF import crashes system | bob schachner | Pro Tools TDM Systems (Mac) | 1 | 11-16-2004 10:29 AM |
Import audio crashes?? | tandem | Tips & Tricks | 1 | 02-14-2003 05:16 AM |
