Old 09-15-2022, 03:15 PM
JR Fountain JR Fountain is offline
Default S3 not firing key commands via EUCON...
Recently updated to a Mac Studio Ultra, macOS 12.5.1, PT2022.7, EUCON 2022.4.
I had KEY commands setup on the right control buttons of my S3 and they are now no longer working. The buttons themselves are good as I tested with EUCON commands and they fire properly.
Anyone else experiencing this?
Thx!
J.R.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
Old 09-15-2022, 06:11 PM
BScout BScout is offline
Default Re: S3 not firing key commands via EUCON...
Make sure you have given security privileges to Eucon for accessibility since key commands are transmitted that way (like a keyboard.) This is different from eucon commands.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Old 09-16-2022, 08:26 AM
Thx for the tip BScout. I have EuControl and MC_Client selected in Security & Privacy > Privacy > Accessibility. Is there another spot I should check? I thought that was it.
J.R. Fountain
Old 09-16-2022, 08:43 AM
EddieJones's Avatar
There are (plenty) of bugs in MacOS at the moment. Try removing them from the accessibility settings, reboot and add them back.
Old 09-16-2022, 12:54 PM
Bydy Bydy is offline
We had a similar problem, the fix that Eddie posted is exactly what worked.
Old 09-19-2022, 08:36 AM
Thanks for the suggestion Eddie. Unfortunately I've tried it a couple times and it hasn't worked.
J.R. Fountain
Old 09-19-2022, 09:31 AM
EddieJones's Avatar
Can you try making a key command for a text app and see if that works?
Old 09-19-2022, 01:23 PM
Hey Eddie,
Just tried making a key command to type "f" in TextEdit, but did not work. Is that what you meant?
J.R.
J.R. Fountain
Old 09-19-2022, 02:38 PM
EddieJones's Avatar
Hey Eddie,
J.R.
Yes. Out of interest did you do a migrate or fresh install?
I'm still sure that this is the same issue. did you try this. Remove EuControl and MCClient from the accessibility settings and uninstall EuControl. Reboot and install EuControl and accept any requests to add again.
Old 09-20-2022, 09:49 AM
Fresh install, but I did bring my 2021 appset XML over.
Just tried removing, rebooting and re-installing Eucontrol but still does not work.
FYI, I am not able to deselect MC_Client from Accessibility, only Eucontrol.
J.R. Fountain
Eucon commands that don't seem to work. mattrixx Avid S1, S3, Dock and Control App 0 02-19-2020 10:49 PM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 11:09 AM
V2.2 new EUCON commands. Marsdy Avid S4/S6 10 08-10-2016 09:12 AM
Can I use a maco with 2 eucon commands? Brandonx1 Artist Series 3 04-07-2012 08:54 PM
Eucon commands not stackable? robertg Artist Series 5 12-15-2011 11:15 AM
