Old 08-28-2022, 10:23 AM
herrturtur herrturtur is offline
Default Re: alt, shift, 3 not working
Originally Posted by Ale View Post
solved:
In fact the consokidate command always opened the task manager.
So i went to the keyboaard shortcuts window an deleted its command.
Strange because task manager command was given shift alt #
which should not react when I press the consolidate keys shift alt 3
But now it works again
Ale
how did you delete the task manager window command? Just can't figure it out. Thank you
> Oh I just found out that with the 22.04 update they introduced the keyboard shortcut manager (option shift k) - haha, thanks anyway!
Old 08-28-2022, 10:36 AM
JingleDjango JingleDjango is offline
Both number row and numpad work for me on macOS 10.14.6.
Old 08-29-2022, 07:21 AM
bernstudios bernstudios is offline
same here and interested in a fix too!
Old 09-01-2022, 03:36 PM
EmilILönneberga EmilILönneberga is offline
Same here.
The shortcut now opens the Task Manager even tho the shortcut manager mentions the consolidate short cut (alt/opt+shift+3) and (alt/opt+shift+NUMPAD3)
correctly. The latter still works.
Old 09-03-2022, 02:58 AM
Originally Posted by EmilILönneberga View Post
Same here.
Follow up:
I can make it work again if I delete the original shortcut for the task manager, but we’ll, then the original task manager shortcut also doesn’t work anymore.
Any ideas?
Thank you!
  #16
Old 09-03-2022, 09:08 AM
ZerglingPhilosophy ZerglingPhilosophy is offline
Same issue as OP. Thought I was going crazy.
  #17
Old 09-12-2022, 05:14 AM
Follow up:
Any ideas?
Thank you!
how can I delete the task manager shortcut?
  #18
Old 09-12-2022, 08:09 AM
ctrl + shift + k opens the keyboard shortcuts manager.
Type in the ‘search by key’ box ‘task manager’.
This will show you the shortcut for task manager.
Hovering over the column ‘key combination’ will show you an ‘x’ next to the
Key combination.
Click on it to remove the shortcut.
Click on the reset button on the right side to undo.
Please mind that the shortcut for task manager (opt + shift + #) will no longer work as well.
  #19
Old 09-29-2022, 12:37 PM
Same issue in 2022.9 unfortunately..
  #20
Old 10-05-2022, 02:08 AM
key combination.
thank you!
Alt+Shift+3 not working ebjazz Pro Tools 2019 12 11-20-2019 02:36 PM
Shift+Tab not working? bing181 macOS 2 06-01-2017 10:58 PM
pitch shift not working aimeepink macOS 1 03-11-2012 07:50 PM
Shift-tab not working...? JKD99 Pro Tools TDM Systems (Mac) 3 02-08-2011 03:22 AM
Pitch Shift not working djhoff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-04-2006 12:59 PM
