Old 04-26-2019, 04:01 AM
Audiooo Audiooo is offline
Default 5.1 Pathway is not showing up in Master Output Drop Down Menu
I am having a strange error with 5.1 output pathways. I am currently trying to take a number of sessions that were originally mixed in Stereo with a straight LR master output and convert them to 5.1.
I have gone into the first session and created a new 5.1 Pathway in the I/O Setup menu. Then I have created a new 5.1 Master Ouput. The new pathway I created exists in the Output Fader I/O Drop down menu fine and I am able to assign this pathway to this Master Output and am hearing signal. So far so good.
However when I open the NEXT session this 5.1 pathway is not seen in the drop down menu when I create a new Master Fader. It still exists in the I/O Setup menu when I check it. However I cannot create a new Master Output channel that will see this pathway in its drop down menu.
I CAN however create yet ANOTHER 5.1 pathway in the I/O setup whilst having this file open and this one DOES appear in the drop down menu of any new 5.1 Master Fader. However if I create such a new 5.1 Pathway it tells me that it cannot exist on the same channels, at the same time as the original one I created in the first session.
Because that first 5.1 Pathway still exists in the I/O Setup there is a clash if I try and create a new one. So I am not able to just create a new 5.1 Pathway per session. What is the way to work around this problem? Should a 5.1 Pathway created in a session not appear in all subsequent sessions globally?
I am running a PC with an Intel i7-4770 CPU @ 3.4GHz
Windows 10 Pro
Soundcard RME Hammerfall DSP Multiface II
32 GB RAM
Pro Tools Ultimate Version 2018.4.0
Any help on this matter would be much appreciated.
Old 04-26-2019, 07:15 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: 5.1 Pathway is not showing up in Master Output Drop Down Menu
IIRC any sessions that were originally stereo will open with the original output master no matter what the I/O settings are, unitil/unless saved with a 5.1 Out. Any new sessions should have 5.1 as an option in the Create screen.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2022.9 Studio through an A&H Qu-32
Old 04-26-2019, 10:04 AM
BScout BScout is offline
When you open your next session, you need to go to the bus tab and link the output to a bus.
When you create a new output on the output tab, it is auto creating this bus to output link but when you open a new session, only the output remains but the bus is not carried over with a link in order to maintain what your previous bussing was in the session. So you need to manually link it on that tab.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Drop Down Menu Glitch Ke productions Pro Tools 12 8 04-23-2016 08:22 PM
Input drop down menu off screen blizzard Pro Tools 11 0 03-30-2015 05:11 PM
Favourites in PT Drop Menu ThisIsSick Tips & Tricks 1 09-26-2009 06:12 AM
Drop down rates in RTAS menu???? fantom27 Pro Tools TDM Systems (Mac) 4 03-20-2007 03:26 AM
Some plugins don't appear in drop down menu. lowfreq33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2006 08:41 PM
