Old 06-07-2016, 03:19 PM
jonathan jetter jonathan jetter is offline
Default 12.5 crashes, perma-pinwheel upon reopening session
hell of a day here- constant crashes from 12.5 with client attending a mix session.
reasonably sized session (~50 audio tracks, ~12 instrument tracks, a few FX returns, and half a dozen melodyne instances), but nothing i haven't done before.
CPU + Memory usage are nowhere near peaking.
crashes seem to be linked to autosave, as the last autosave is always exactly 5 minutes prior to the crash (my autosave interval is set to 5 minutes).
so i'm assuming that PT crashes because i'm doing a certain something during the new autosave.
this wouldn't be the end of the world, except when i re-open the session, it permanently pinwheels. i can re-open with plugins inactive, and then go through and activate them a few at a time (reactivating them all at once pinwheels again).
HD Native 12.5, OS X 10.10.5, Silver Mac Pro Tower.
any ideas? thanks in advance,
Old 06-07-2016, 04:16 PM
Extreme Mixing Extreme Mixing is offline
Default Re: 12.5 crashes, perma-pinwheel upon reopening session
I got this advice from Melodyne and it helped my day go a lot smoother. Since You have Melodyne in the session, I'd try it.
Dear Steve,
In this case please delete the "Melodyne singletrack" preferences under
[macintosh hd]/[users]/[- your user account -]/[library]/[preferences]
The two files in question are:
com.celemony.Melodyne singletrack.plist
com.celemony.melodyne.singletrack.plist
To quickly find the files listed above please go to the finder and use the keyboard shortcut
SHIFT + COMMAND + G
and paste this line in the upcoming window:
~/library/Preferences/
Once the files got deleted please shut down your Mac and restart it after a short break, then try this again.
Should the problem persist, then I need to know also the Protools version you’re on.
Best wishes,
Jörg Hüttner
See More from Steve Shepherd
Good luck.
Steve
Steve Shepherd
Extreme Mixing
Old 07-11-2016, 01:18 PM
berrysongs berrysongs is offline
Steve, can you post as to whether throwing these preferences away worked? I want to see if this will work on my end, but I'm affraid of losing any Melodyning that we have already done. Thanks!
Pro Tools 11 pinwheel on session load after Yosemite upgrade Kylemarek Pro Tools 11 4 05-17-2015 05:56 PM
PT11 pinwheel at session load reed_safehaven Pro Tools 11 6 12-18-2014 09:25 PM
Problem with reopening session saved in pt5 gbr8 Windows 0 06-04-2012 06:26 AM
Session layout not being remembered after closing/reopening a session/Pro Tools! DJ Hellfire Pro Tools 10 1 12-23-2011 01:05 AM
Loud distortion from playback after reopening session. spaceagedevice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-11-2007 05:42 PM
