Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 09-25-2011, 09:13 AM
Dave Ray Dave Ray is offline
Default [RESOLVED] Unable to rectify error 'Current Playback Engine doesn't support 44.1 kHz'
I'm a first time Pro Tools/M-Audio user. I've just acquired a Fast Track Pro which comes with Pro Tools SE. I am running an iMac OS 10.6.8.
I can record and playback properly in Garage Band, however I'd like to use Pro Tools SE as I understand it is compatible with Sibelius 7 which I will be loading in the next couple of days.
Having loaded Pro Tools SE, if I try to open a new session or a demo session in Pro Tools SE, I get this error message:
'Current playback engine does not support a sample rate of 44.1 kHz'.
I have attempted to set the input and output in Audio MIDI Setup to the in-built system and also tried to set the input and output in Audio MIDI Setup to the Fast Track Pro. I have also reloaded Pro Tools SE to see if, by reloading the application and the device driver, it would make a difference.
I can't open up a session in Pro Tools SE to enable me to access any menus it may have that could resolve the problem.
I'd appreciate your help.
Old 09-25-2011, 09:34 AM
Default Re: Unable to rectify error 'Current Playback Engine doesn't support 44.1 kHz'
Apologies to all. In searching wider, someone had encountered this problem with the M-powered version. The trick was that I was using a connection via S/PDIF at 48 kHz and for some reason that upsets playback.
Problem solved.
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 06:32 AM
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 11:10 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 10:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 10:26 AM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 04:21 AM
