Old 02-11-2011, 07:03 AM
zenstone zenstone is offline
Default How to split a stereo bus into 2 mono busses
Is it possible to split a stereo bus to 2 mono busses/tracks?
I want to treat the left and right channel seperatly without using special multimono plugins.
I've tried a few things, but I always end up in a summed mono bus, which i don't want.
A multimono stereo bus means it has 2 mono busses combined, so how can you split them into 2 mono busses in pro tools?
Any ideas?
R
Old 02-11-2011, 08:25 AM
anothercolour anothercolour is offline
Default Re: How to split a stereo bus into 2 mono busses
Maybe I am misunderstanding your question, but you can use mono sends to feed mono auxiliary tracks, and then put individual plugins on the mono auxiliary tracks.
Hope that helps.
Old 02-16-2011, 05:05 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Two mono aux tracks, LeftBus as input on one, and RightBus as input on the other. My logic anyway.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16GB RAM. 512GBinternal(3000MB/s),2TB(1300MB/s),2TB(350MB/s)
MacOS 11.6.8. PT 2020.12.1 (Reinstatement on hold for M3 macs and AS native PT)
Topping D50 DAC, Dynaudio BM6p, Artist Mix, SSL UC1, EuControl on iPad.
Old 02-16-2011, 06:05 PM
Stig Eliassen's Avatar
Right-click track (aux) name -> Split into mono
Since the number of input channels for any multichannel plugins doesn't match with the two new mono auxes, the plugins won't carry over. But, you can switch the plugin(s) to multi-mono before you split the stereo aux into mono, and then they will copy over to the mono auxes. Lastly, assign the inputs for the mono auxes, and you should be done.
Mixture of Mono and Stereo busses jeremy@jjlee.com VENUE Live Sound Systems 5 12-06-2012 12:59 PM
Stereo EQ3 doesn´t split to mono Frank Kruse Post - Surround - Video 0 04-15-2010 04:57 AM
Split stereo into to mono Nesp Pro Tools M-Powered (Win) 3 03-04-2010 01:03 PM
2 mono split - to 1 stereo file rinky Pro Tools TDM Systems (Mac) 3 06-28-2006 05:18 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 05:02 AM
