Shortcut-Quantize
Since I updated to PTLE 6.4 shortcut "alt0" quantize doesn΄t always work
Somebody have a clue /Dennis
Mac Pro 2.66 1gb Ram MacOS X 10.4.8 002R PT 7.3.1 |
Re: Shortcut-Quantize
I get that sometimes too, usually when a session is very full...also, when I change my pre-roll, PT won't play or record until I click on the top of my screen (it appears pale blue, and becomes a darker blue when I click it). Then it works perfectly...strange by true.
But these are minor bugs that don't slow me down much...when the quantize 'shortcut' doesn't respond, I just pull down the menu to quantize. Hopefully, Digi will see this and straighten out these 'bugs' as they have in the past. -Roy
rh music |
OK...but with v6.1.1 this problem never accured? Someone else that have a clue?
/Dennis
Never seen that happen here.. but make sure you don't have the intermittent sticky START key issue.. if it happens again toggle the Start key a few times to see if it helps. Also don't hit the ALT key alone and release it and then hit Alt+0.
Rail
i've often had problems with the Ctrl key. i used to think it was my keyboard, but when the kids spilled coffee on it and i replaced it, the same thing happened. i think in general, PT loses focus often: window focus, mouse focus... sometimes when you open a plugin, keyboard commands lose focus and that sounds like this guy's problem. it's definitely roy's problem (the title bar changing color gave that away). this is definitely a bug - minor but annoying.
i played around with sonar 2 a while back and the MOST annoying thing about it was you had to put the window in focus before you could use the mouse. i.e. if the track window was in focus and you wanted to move a fader in the mixer window, you can't just grab the fader and go, you had to click in the mixer window first (to put it into mouse focus) before you had the ability to move the fader. that was SOOOOOO annoying...
i love my apple iPhone! |
I've never seen any key have this issue except the START key in Windows.
Any other focus issues have always been 3rd party plug-in related... like if you have a Waves plug-in open.. it eats the keystrokes due to the nature of the way they've coded their plug-ins via a shell. Rail
coukd be something else ..... if you have uoir keyboard for 2 languages , the change with alt+shift .... it could be tha you have change tha language on the keyboard and PT can't read it .....i think...
www.dus.gr |
and i see that i have big fingers and i press all the letters on the keyboard so i can't write a word right
www.dus.gr |
quantize shortcut! help | audioplace estudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-21-2011 01:51 PM |
quantize shortcut doesn't work -- bug? | c-post | MIDI | 1 | 07-10-2004 10:15 PM |
Quantize Shortcut? | tomhartman | Pro Tools TDM Systems (Mac) | 0 | 11-02-2001 10:22 PM |
Quantize Shortcut Key | curtom | Pro Tools TDM Systems (Mac) | 2 | 06-08-2001 11:36 PM |
Keyboard shortcut for "input quantize"? | musicfamily | Pro Tools TDM Systems (Win) | 0 | 09-26-2000 11:53 AM |
