tip: PC/MAC Plugin Wormhole (Audio over TCP/IP) !!
Hello,
look at this Plugin !!! Waited years for it !!! Wormhole You can use a cheap pc beside your mac for adding Native Instruments/Effects if you use a sequencer thats running with AU or VST Plugins. Great But use only Gigabit Ethernet ! Works great ! I have nothing to do with this company, only love this ! And if you want to also send midi from mac to pc use midioverlan !! midioverlan Thats realy cool, i can now throw my cables and audio card also from pc away. And it is a cool addition to your ProTools system. Digi you should buy these both companys for the intilgence of the products. Cool thing ! Greetings Walter And they are realy f***ing cheap. |
Re: tip: PC/MAC Plugin Wormhole (Audio over TCP/IP
Good find... I'm very interested to find out hw far it can be pushed.
Thanks for the spot light.
Justin Davis Rocky Mountain Recorders |
Re: tip: PC/MAC Plugin Wormhole (Audio over TCP/IP) !!
$169 for a 4-port midi over lan interface? Unless someone tells me the latency is significantly less than a hardware midi interface, it's hard to justify...
Is the latency significantly tighter than hardware midi interface (RME HDSP 9652)?
--Jeremy |
J5 wormhole Switch | joellegros | VENUE Live Sound Systems | 1 | 02-04-2014 12:12 PM |
vst plugin and m audio | martinbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-29-2007 12:21 AM |
Audio over LAN? (Plasq Wormhole?) | Sty1es | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-29-2005 11:42 PM |
Wormhole in PT 6.7 | Marketis12 | Pro Tools TDM Systems (Mac) | 0 | 03-14-2005 12:29 AM |
Anyone using Wormhole with PT6.7? | command_shift | Pro Tools TDM Systems (Mac) | 1 | 01-14-2005 02:54 AM |
