Old 11-13-2009, 07:53 PM
Pred80r Pred80r is offline
Default Track levels in session keep changing when the session is re-opened.
I am losing my mind over this, I am running a Mix ++ system with 3 888's all synced to an aardync wordclock on a G4 1.25 ghz mac with 2 gig of ram. I am using pro-tools 6.4.1 on osx 10.3.9 and a 64 bit pci expansion bay to hold the cards. on this particular session I am using some UAD powered plugs with a UAD-1 but this issue is occuring to tracks that don't have UAD plugs as well.
I am mixing this session ITB to the SAME 2 outputs on my 888 's every time so I think I have eliminated that possibility. I will sit down for a couple hours refining my mix making subtle adjustments here and there, mostly level changes to get things to sit right, some compression, adjust some send timing etc etc. I get a mix that sounds and feels like it is approaching it's final stages so I bounce it down and then burn a cd to listen to in the car (like most of us do at this stage, right?)
I make some notes to take back with me to the session, feeling excited that I am close to a "final" mix and when I open the session I can't believe my ears.
Yes I save often and always when I close Pro Tools. so it is not that my changes arent being saved. .in fact I can see the volume and automation tweaks are still right where I left them. When I go back to the session some track levels are just off, some a little off some are WAY off. I fixed a harpsichord to sit in the mix with the guitar and when I re-open the session it sounds like a harpsichord solo it's so far on top of the mix. One time some tom fills are way too punchy and in your face the next I can't even hear them. Sometimes it's the hat thats too loud sometimes it's the ride. Sometimes the kick snare combo going through a drum buss with compression are flat out rocking and sometimes they are just falling flat.
What could possibly be causing my track levels to bounce around like this? I mean I guess I could be going crazy and maybe it is just my ears, maybe I should quit...been doing it too long I guess. Has anyone else experienced this and how did you resolve it?
Thanx in advance,
Jack
Old 11-13-2009, 08:58 PM
Craig F Craig F is offline
Default Re: Track levels in session keep changing when the session is re-opened.
+6 or +12 fader?
Thank you,
Craig
Old 11-14-2009, 12:00 AM
blackmacdaddy blackmacdaddy is offline
This is an old bug fixed in 2004. You must run 6.4.1cs4 - update and your problem will be gone. it is in the cs downloads section here. Best W
It's only R'n'R but I like it.
Old 11-14-2009, 01:31 AM
+12 fader...
Thanx for the tip on 6.4.1.cs4 update, let me try that and see what happens.
Keeping my fingers crossed!
opened old session, track out of sync.anyone? musicmixer04 Pro Tools TDM Systems (Mac) 1 02-17-2011 02:14 PM
Crash when New Track is made or session is opened ShaunYouth Pro Tools 9 1 11-10-2010 03:15 AM
Changing track input/output assignments corrupts session files, causing PT to crash. horribleheaven Pro Tools M-Powered (Win) 1 07-08-2010 11:47 AM
can PT LE 7 session be opened in PT LE 5.2 ? schoen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-12-2005 05:44 AM
Can a 5.3 session recorded with HD system be saved as 5.1 session and opened on mix s Ricky Cobble General Discussion 0 02-03-2003 02:10 PM
