Old 02-07-2025, 01:13 AM
tijnwete tijnwete is offline
Default Custom re-renders import pro tools
Hello.
I’ve made a template mix session in Pro tools wich includes custom-re-renders.
When I start a new mix and import the data from the mixtemplate it seems that it does not import the custom re-renders.
When checking via the IO setup it’s empty.
Does anyone has the same problems?
Thanks in advance
Old 02-10-2025, 06:47 PM
Dizaineris Dizaineris is offline
Default Re: Custom re-renders import pro tools
I believe you need to make the new session from the template.
Not new session and import session data.
Old 02-12-2025, 03:26 AM
tope d's Avatar
tope d tope d is offline
Originally Posted by tijnwete View Post
Hello.
Thanks in advance
Hi there,
Can you share your steps on how you created your template?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
2024.3: new "custom re-renders" Offline Bounce doesn't work? Fabi Pro Tools 5 05-31-2024 04:35 AM
Can't import Custom Faders.. Help? polyh3dron ICON & C|24 2 01-16-2018 10:01 AM
pro tools slow performance renders it unusable. falcondoodle Pro Tools 11 17 04-19-2017 06:32 PM
Warning: New pro tools upgrade renders b4 useless billkahler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2009 10:21 AM
Import custom faders bank Pythagor ICON & C|24 2 04-28-2006 03:04 PM
