Old 12-03-2010, 04:13 PM
soul's Avatar
soul soul is offline
Default Can't open PT7.4 file in 8.0!
I am finally trying to make the transition to PT8. I have a session from PT 7.4 that I need to open. Its a template file of sorts.
Every time I try to open it PT crashes. I have taken out any plugs that might be incompatible. I am wondering if it is related to IO configuration or something like that changed between the two versions.
Any ideas or suspicious things to look for?
I have PT8 and 7.4 on separate startup disks on the same G5. Both systems were installed at the same time a year ago. PT74 runs fine, I am just now starting to use PT8.
HD2 / 96io / 2.7 dual G5 PCI / 2 GB
thanks!
Old 12-03-2010, 04:17 PM
Dism Dism is offline
Default Re: Can't open PT7.4 file in 8.0!
thanks!
Have you tried using Import Session Data?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-03-2010, 05:31 PM
Sean Russell Sean Russell is offline
Default
8.0 or 8.0.1cs2?
... but does it help the chorus?
Old 12-03-2010, 06:11 PM
formfunction formfunction is offline
Have you tried other 7.4 sessions ? from your post it sounds like it's just this one. Do as dism suggested and import the tracks into a newly created 8 session.
Old 12-04-2010, 08:51 AM
soul's Avatar
8.0.1cs2
yes I've tried session import too.
thanks for the input.
Old 12-04-2010, 10:55 AM
axiom axiom is offline
Did you try importing one track at a time? You might be able to narrow it down to one corrupt track.
Will Loconto
www.WillLoconto.com
Old 12-04-2010, 12:43 PM
soul's Avatar
Got it! Autot Tune 4 incompatible.
What's the cheapest way to get Autotune 5 or whatever version is needed for pro tools 8 compatibility?
thanks again all.
Can't open PT 5.1 file in PT 7.4 doodee72 Pro Tools TDM Systems (Mac) 3 07-27-2009 02:36 PM
File not open (-38) omnipop Pro Tools TDM Systems (Mac) 2 04-24-2009 07:06 PM
File not Open (-38) Bigpit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2008 11:30 PM
Open up a .pt5 file! MikeGSPR Pro Tools M-Powered (Win) 3 03-13-2008 06:53 PM
Can't Open/Create new file from File Menu nob turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-07-2003 11:04 PM
