Old 11-05-2010, 08:08 AM
Edacman Edacman is offline
Default Pro tools "Any Hardware" Clause
Hey i was wondering.....Avid says that with pro tools 9 you can use any hardware. so does that mean that you dont need digidesign hardware to get audio into the DAW? would i be able to use pro tools 9 with a tascam DM-3200 and not need any digidesign hardware? and would i be able to mix with it as my controller as well?
Old 11-05-2010, 08:12 AM
Holly73 Holly73 is offline
Default Re: Pro tools "Any Hardware" Clause
Exactly!
I don't know the DM-3200, but if it works as a control surface supporting HUI, then yes!
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 11-05-2010, 08:13 AM
tobbenos tobbenos is offline
As long as the audio interface is uses asio/CoreAudio, you can use it.. You might want to take a look here.
Old 11-05-2010, 08:17 AM
danander11 danander11 is offline
Well, since I, (and a few others) cannot get PT9 to start even with Digi hardware, it would be nice if it worked with something...
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
[IMG] code is Off
Pro Tools "install hangs at Installing Digidesign hardware drivers" Bulley Pro Tools M-Powered (Win) 12 08-16-2012 07:53 AM
Solution: "Unable to locate M-Audio Hardware..." Pro-Tools 8.0 M-Powered on 64 bit OS bnorrgar Pro Tools M-Powered (Win) 6 06-26-2012 12:02 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Producer USB mic disabling Pro Tools from recognizing "M Audio Hardware" justin22 Pro Tools M-Powered (Win) 3 03-27-2010 07:34 PM
Axiom 49, Pro Tools M-Powered 7.4 CS2 : "Unable to locate M-audio hardware" Sleightmind Pro Tools M-Powered (Win) 9 08-15-2008 07:07 AM
