Strike - Content Not Found Message When Opened 1st Time
I just loaded up Strike 1.0 for the first time and installed the update and it pops on the screen with a flashing "Content Not Found" message telling me to run the Set Content Location app. I found that app on disc one of Strike but can't make any sense out of it. I installed both Strike discs to my main main Mac HD. They're in the library/App Support/Digi/Plugin file where I thought they were supposed to be. Like most I actually record to a separate Firewire HD. Any help would be greatly appreciated!
Mac G5 2.7 dual PT 7.1 3.5 ram |
Re: Strike - Content Not Found Message When Opened 1st Time
I installed all the samples to a separate drive but .... unless someone else has a better fix - uninstall it and reinstall it if you haven't already. After that, pull the rip cord. Did the first version work before you did the upgrade? Make sure the first one works before you upgrade and then make sure the settings on the install on the upgrade match the original install settings.
Thanks Jim - I haven't tried to reinstall it and no, it didn't work with the first version. I'll give it a try.
STRIKE content not found [solved] | john1192 | Virtual Instruments | 34 | 11-04-2015 12:16 AM |
Strike - Content not found | Vincent Joly | The Drum Room | 5 | 10-02-2011 06:21 PM |
Strike - Content not found | xq3js | Virtual Instruments | 18 | 09-29-2009 12:50 PM |
Velvet & Strike: Content Not Found error | thopman | Virtual Instruments | 13 | 07-20-2009 06:14 PM |
Strike Content File not found | atomicaudio | Virtual Instruments | 1 | 07-01-2007 06:55 AM |
