Old 06-01-2006, 02:00 PM
billymc billymc is offline
Default anyone using vdrums to map midi
hi i'm using a roland td-7 to try and create drum tracks that i can play back through bfd. is there anyone using them that could give me some pointers. the midi notes hardly ever fall into the right spot on the grid. it is a total disaster. i have mbox 1 and an edirol usb midi device.
thanks, bill
www.niagararocks.com
Old 06-01-2006, 06:42 PM
x9blade x9blade is offline
Default Re: anyone using vdrums to map midi
hello, i use a td 20 all the time and have no problems with notes falling in the right places.are you maybe having a latency issue? what buffer setting are you using when you track midi?which digi hardware are you using?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 06-01-2006, 06:50 PM
RolandK RolandK is offline
I used to have a Yamaha e-drum kit and had different presets that mapped the pads to a synth and a software drum kit. I forgot exactly how to do it, but it should be in your v-drum owners manual.
Old 06-01-2006, 07:26 PM
oh are you talking about assigning midi note numbers?
Old 06-01-2006, 09:37 PM
i have the buffer on the max setting 1024. and the dae at 8. i am playing the sounds back with bfd, which i have the proper map installed. the midi notes are being recorded live to a click. there is so much latency that i have to use the roland sounds while playing real time while mapping the notes. during play back many notes are missing or in way off time than when played, the others are on time. is it because the td 7 is too old, or is my midi device [bleep]. it is an edirol um2-ex. i guess basically it is not mapping the number of hits i am hearing in the same time.
any help would be appreciated.
Old 06-02-2006, 03:50 AM
spkguitar's Avatar
When tracking, the H/W buffer should be set to it's lowest possible setting on your system. The DAE Buffer should not be changed from it's default of 2.
Set your DAE buffer back to 2, and set the H/W buffer as low as it will go and try again.
Old 06-02-2006, 05:26 AM
neeel neeel is offline
this should help you re the drum maps
drum maps bfd
MBOX MINI PTLE 8.0.3
MAC OSX Snow Leopard
Mac Mini 1.5Ghz Intel
2 Gig RAM
Old 06-02-2006, 09:54 AM
no just recording the notes properly. i have the notes assigned as they should be in bfd.
Old 06-02-2006, 09:57 AM
i'll try what you are saying with the buffer and dae. what does the dae buffer do anyway.
Midi hits with roland Vdrums Raoul23 Virtual Instruments 0 08-07-2013 12:29 PM
Can't get Vdrums into Mbox via MIDI... raph105 The Drum Room 4 11-28-2010 01:58 PM
Recording Roland VDrums via 002 MIDI RynoTH MIDI 4 03-29-2005 08:36 PM
How to hook up midi to Vdrums KDK Twelve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-11-2004 08:20 PM
Roland Vdrums and Midi Setup whatwhat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-17-2004 04:59 PM
