Old 01-08-2011, 09:32 AM
modulo2008 modulo2008 is offline
Default Bug about PT 9.0.1
I got BUG from Protools v9.0.1.
I tried to do "sesson copy in" 96k from 44.1k sessions.
But it changed automation about SENDS (mute,level,etc.....)
I can see nearly half position & length than original.
Please fix it,AVID!!!!
Mac STUDIO 24 core M2 Ultra 2023 (128G Ram) / OS 14.4
Pro Tools HDX2 & UAD-2 (20Core)
Old 01-10-2011, 12:55 AM
Default Re: Bug about PT 9.0.1
I uploaded pics about difference data about 96k & 48k.
(please click "view full size" on right-up corner)
http://twitpic.com/3oqex8
UP pic : 96k original session.
DOWN pic : 48k session. imported from UP pic's 96k session.
of course I'm importing same settiing (current time etc....)
Let me know solve this problem.
Old 01-10-2011, 09:25 PM
I found another same problem thread...
http://duc.avid.com/showthread.php?t=282825
But this problem can't solve it.
Let me know good info if somebody know it....
Old 01-11-2011, 05:07 AM
Now I got advice from an acquaintance.
I tried to change time base mode as "Liner tick display" & import it.
The import was successfully when I used this method.
BUT I hope to fix this BUG,Avid tech.
(safety import without changing time base)
Old 01-11-2011, 07:21 AM
Sean Russell Sean Russell is offline
Default
Have you tried posting in the PT9 forum? I believe they have an area set up just for PT9 now...
... but does it help the chorus?
Old 01-11-2011, 08:50 AM
DigiTechSupt's Avatar
I'm going to try to get this looked at today. It's been awhile since the first report of this and I recall we did a fix for it, but maybe something has occurred since then.
Avid Audio Tech Support
Support FAQ
Old 01-11-2011, 09:12 AM
I just tested this and can reproduce what you're seeing. I'll get this logged and a fix looked into asap.
Support FAQ
Old 01-11-2011, 11:18 AM
1m1 1m1 is offline
does this happen in PT 9.0.0?
Old 01-11-2011, 11:32 AM
Yes, that appears to be the case.
Support FAQ
Old 01-13-2011, 01:08 AM
thanks for quickly response. I'll wait for cs update.
