Old 08-08-2022, 10:40 AM
QuacksMeUp QuacksMeUp is offline
Default Normalize VS Gain - is there a difference?
Is there is difference between applying Normalize to a a piece of audio VS manually applying clip gain?
Often it seems Normalize will not boost a clip because of some unseen audio peak... it which case, I gain the clip to match the others that normalize did boost. So they appear to do the same thing, except one is automatic and the other is manual.
Old 08-08-2022, 11:39 AM
Eric Lambert's Avatar
Default Re: Normalize VS Gain - is there a difference?
As you suggested, one is automatic and the other is manual. That's the primary difference. The trouble with manual is that you can easily send a track into the red without immediately recognizing it, as you also described. Besides being quick, Normalize also takes those peaks into account and prevents breaking through the ceiling.
Old 08-08-2022, 03:07 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Another difference (or way to describe it):
Normalize brings up or down the level based on the highest level "peak" in the clip. Pick 0.0 dB or less, and the highest level will be put there.
If your waveform changes little the "peak" must have already been close.
On the other hand, Gain brings up or down the level based on a relative plus or minus dB.
So, a file with -5 dB peak needs +2 dB Gain to be -3 dB peak. But a -5 dB peak needs -3 dB Normalize to be -3 dB peak. Just as an example.
Without enough understanding of dynamics, the RMS modes could be more confusing, and the above discussion is just thinking about peak level.
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
HTML code is On
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Gain and Normalize French links 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2006 06:21 PM
Gain and Normalize French links 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2006 04:34 PM
normalize or gain fumunda Pro Tools TDM Systems (Mac) 18 11-09-2001 03:38 PM
Normalize vs Gain Maltin Tips & Tricks 16 11-14-2000 04:35 AM
