Old 04-11-2022, 08:08 PM
teedeecee teedeecee is offline
Default EuCon - Key Commands - Not Working
I have moved to a new system and been setting up my workflows, and am stuck with using "Key Commands" in EuCon on my Transport. It appears that they simply do not trigger? Has been fine for years and I can't for the life of me work out why its stopped.
Running all latest EuCon / PT on an M1 MBP Max / macOS 12.1
Old 04-12-2022, 10:03 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: EuCon - Key Commands - Not Working
Are these single key commands or macros?
Old 04-12-2022, 03:43 PM
Hi Eddie, hope you’re doing well. In this instance I was just using page down, but I tried page up and also space. Single stroke, no macro.
Old 04-12-2022, 03:47 PM
EddieJones's Avatar
Can you check that EuControl and MCClient are allowed in the accessibility security settings on the Mac?
Old 04-12-2022, 04:27 PM
Yes, they are checked.
Old 04-12-2022, 05:09 PM
EddieJones's Avatar
One way to easily check that EUCON is sending them is to open a text App and program a key or two in that and see if they are even getting through.
Old 04-12-2022, 05:18 PM
No go I am afraid. Tried on other keys on the surfaces and same issue.
Old 04-12-2022, 06:58 PM
EddieJones's Avatar
These images are focused on PT...did you try to assign a key in a text App?
Old 04-12-2022, 07:04 PM
Just unlocked EuCon to PT, checked Eucon is assigned to Application: Textedit, and same issue.
Old 04-13-2022, 12:55 PM
EddieJones's Avatar
It sounds like OSX is stopping them. If you use the EUCON Installer and check uninstall all Apps and all prefs(this doesn't delete softkeys) reboot and reinstall EuControl that might help...make sure you accept any prompts.
Eucon commands that don't seem to work. mattrixx Avid S1, S3, Dock and Control App 0 02-19-2020 09:49 PM
Eucon 'KEY' commands do not work Moviesound Avid S1, S3, Dock and Control App 0 07-19-2017 09:44 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
V2.2 new EUCON commands. Marsdy Avid S4/S6 10 08-10-2016 08:12 AM
Eucon commands not stackable? robertg Artist Series 5 12-15-2011 10:15 AM
