Re: EuControl & Mac Studio
Just set up new Mac Studio ULTRA. Having the same problem.
EuControl sees the surfaces, but Pro Tools doesn’t (neither does Logic.) 3 X S1, +Dock & 4 tablets. Haven’t changed network config from my previous (working) Mac Mini Intel. (Meaning I unplugged my Ethernet network setup from the Mini and plugged that into the Mac Studio. Not feeling network is the issue as Eucontrol sees the surfaces (NO Application in ASSIGN tab with Pro Tools running.) Mac Studio M1 ULTRA Monterey 12.3.1 Pro Tools 2021.20.12. (EUCON IS SWITCHED ON AND I HAVE TOGGLED/REBOOTED ETC>) EuControl 2021.10.1.29 (EuCon 4.8.3.29 My brother received his a couple of weeks ago and his (single) S1 is working. The only difference is he is running 12.3.0 and I did the (Apple) recommended 12.3.1 upgrade on install… could this be it? (AVID are you listening???) Can I roll back to 12.3.0 without starting over? (Erase, reinstall, re-migrate)? Otherwise Pro Tools running smoothly (albeit 4 unhappy plug ins: Stratus 3D, VisLM, Slapper, Lexicon PCM (ancient)) I need surfaces working… help! |
An interesting discovery: The soft keys will work in Pro Tools although the faders will not engage. |
Are all softkeys working including EUCON ones or just keyboard shortcuts? Can you check the Workstation tab in EuControl and make sure its in the right hand box and attached?
I tried reinstalling Pro Tools via both Avid Link & downloaded installer and same with Eucontrol. Reinstalled Monterey via Recovery which reinstalled 12.3.1 - have hesitated on wipe and clean install as it’s time consuming to reinstall interfaces drivers and 3rd party plugins, but guess I will have to try that next. (This was a migration from a Big Sur 2018 Mac Mini.) I too noticed that the soft keys from Pro Tools/Logic appear on the MASTER TABLET, though greyed out and changes state with application switching. Pressing corresponding button on dock works to highlight soft keys, though nothing else happens. My named memory locations appeared there. No change in the S1’s, dock and other tablets. They are in the ready (connected to EuControl) state (ie no Avid logo - squares) All surfaces show as connected in EuControl. Logic not seeing EuControl options (Mix menu) EuControl assign page still doesn’t show the application name (both PT and Logic.) Layouts don’t load from session. Open to thoughts. |
#16
I should mention that I also tried running EuControl in Rosetta. It still saw all the surfaces, but did not show the soft keys… Right hand box in WORKSTATIONS tab in EuControl is checked, I’ve toggled this as well. On the S1’s, the Inserts,EQ,DYN,Aux,Pan buttons light up when pressed and are linked across the 3 S1’s, as is SHIFT. Nothing else lights up or has an effect… Last edited by imixit; 04-22-2022 at 11:04 AM. Reason: Additional information |
#17
The controllers are appropriately connected in the workstation tab. |
#18
I think we're at a point where we need either an updated Pro Tools or EuCon software version to get controllers working on M1 Ultra. |
#19
#20
What versions of PT and EUCON are you on? EUCON has been Apple silicon Native since 21.6
EUControl not working as Makie or HUI with Studio One? | Captain Al | Artist Series | 20 | Today 09:33 AM |
MTRX-Studio activation card # won't work. How do I get EuControl? | DeadlyMixProd | Avid S1, S3, Dock and Control App | 2 | 12-29-2021 05:29 PM |
Can ProTools Vocal Studio work in Pinnacle Studio 14.01.7256 | Sharon Lee Taylor | Pro Tools SE and Essential (Win) | 2 | 08-28-2010 08:39 PM |
Logic Studio taking files to pro tools studio. | smoochdaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2009 10:55 AM |
Studio interrior! Let's show them home/appartement /garage studio's :) | Gr0und_Zer0 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 200 | 05-18-2003 05:40 AM |
