Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 02-15-2022, 09:08 AM
FJ92 FJ92 is offline
Default Setting a PT HD rig with a sync HD device as the slave to a DCP
Hello,
I could use some advice on the following: We've got a DCP on a DCP 2000 server running that needs a PT session to sync to it as a slave. How would I best go about setting up the PT session to follow the LTC that the DCP will generate?
Thank you in advance,
F
Old 03-02-2022, 02:36 AM
Default Re: Setting a PT HD rig with a sync HD device as the slave to a DCP
Patch LTC from DC server to SYNC HD and send same trilevel master video ref to both the SYNC HD and DCP server and make sure the DCP server is locked to ext video ref.
Set PT to
clock master: SYNC HD
Clock Reference: Video Ref.
Ref format: set to whatever your clock is set to. (most likely 1080P24 if it's a 24.00fps film).
Then hit command-J (chase external LTC) in PT.
The clocking is important otherwise they will drift apart over a long film.
F
Syncing with an RC-300 Looping Pedal -or- How to Slave PT to an External MIDI Device? zhuzh_michael macOS 1 02-17-2022 07:41 PM
Setting LE as slave to receive MTC Wollygas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2009 11:02 PM
Tempo Fluctating on Slave device w/MIDI BEAT CLK polaredit MIDI 0 08-22-2006 04:57 PM
Slave Protools M-Power to older midi drum device jazzyeric MIDI 0 03-29-2006 09:03 PM
Is it possible to make PT a slave to another MIDI device (such as a Roland VS machine Mikchek MIDI 7 03-02-2002 10:38 AM
