Session wont play
My session that was created in a lab on a different iMac wont play on my home iMac when I load the session. There is no output selection for my Saffire Pro 40. Please help.
Re: Session wont play
Open Setup>Hardware and make sure your interface is the selected audio engine. Next, open Setup>IO>Output tab. Make sure the option for "Session Overwrites IO Settings is UNchecked. Then on the outputs tab, if you don't see the outputs for your interface, I would delete all paths and hit the DEFAULT button. Then check the input tab(the idea is the have all of your usual IO paths available, and to remove any paths that don't correspond to your interface). Then hit the BUS tab and look for any paths that are in italics(and UNcheck them).
I did everything correctly and still cant get the session to play. Mot making any sense to me. I'm not a rookie either. Please help further if possible. Thanks Dave!
Did you check to see that the Saffire is the selected audio engine?
Yes sir I did. So after sleeping on it, I came to the conclusion that I recorded the session in the lab at 44.1KHZ and my Saffire Mix control says 48KHZ as the sample rate however, it wont let me change the sample rate because it is clocked to an Octopre and locked. Any suggestions? Thanks again Dave!
Chris
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Pro tools 10.1 I open session tracks wont play says output map is currently inactive | shamanrock | Windows | 16 | 01-23-2013 06:22 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
Protools Wont Play | DJLilSteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-03-2009 02:27 AM |
My session wont play -7401 dae error | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-28-2004 03:25 PM |
6.4 wont play | mersisblue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-29-2004 11:11 PM |
