Old 10-19-2007, 12:10 PM
Rectifried Rectifried is offline
Default Keyboard shortcuts for macbook
As a longtime HD user I finally got an LE setup with a Macbookpro
however all the {apple+1= transport.etc} commands are not the same on the macbook...have I missed something with the world of mac...i cant find anything about this on this site...or its very discretly tucked away...
thanks
H
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 10-19-2007, 12:34 PM
webby webby is offline
Default Re: Keyboard shortcuts for macbook
You will need to also hold the function key (fn).....
Old 10-19-2007, 01:04 PM
thanks for the reply
but holding the fn and the apple key plus a number 1 doesnt not show/hide the transport or any other of the windows..anyone else want to guess this?
Old 10-20-2007, 02:20 AM
Are you using the numeric keypad numbers? I use a Macbook and this works for me. Function +Command + 5 for example will open your memory location window. Function +Command +1 should also open your transport.
Defo works, use it all the time.
Old 10-20-2007, 12:39 PM
Shawn Simpson Shawn Simpson is offline
Sure. This isn't a guess...
Webby is right. You have to hold down the function keys and actually press the "alternate numeric keypad" keys located on the right side of the keyboard. J=1, K=2, L=3, U-4, etc...
If you enable the num lock function you can use those alternate keys without pressing the fn key.
Old 10-20-2007, 02:13 PM
Yes webby and shawn thanks your very right.I didnt notice this...
But the real function Im missing now is the; turn off click [7], or midi merge[9]...that are accessed from the numeric keypad on the right side of the mac full keyboard...Midi is hard enough in pt..
thanks for your help
Old 10-21-2007, 04:09 AM
7, 8, 9 numeric keys are reflected on the normal 7, 8, 9 keys.
Old 10-22-2007, 02:36 AM
thank you webby....i needed the numbers lock..
Old 08-14-2011, 11:06 PM
Lisle Lisle is offline
I'm re-opening this issue in the hopes that someone else is experiencing a new problem: I'm running PT9 on my 2010 aluminum unibody Macbook Pro 6,2 (Rev H), and system 10.6.8. This model has no num lock key, and no alternate number values for J,K & L like the previous Macbooks did. I'm trying to access the window shortcuts with no success. I bought an external Targus USB numeric keypad (PAUK10U) in the hopes that it give me this functionality, and although it works for numeric entries, no luck with the windows, even with different fn and command/apple key combos. Has any genius figured this out for the newer Macbooks?
Old 08-11-2022, 12:25 AM
jeremiahmoore jeremiahmoore is offline
Ha, reviving this thread for M1 Macbook Pro in 2022!
Anyone found a way to access numeric keypad using the laptop keyboard?
I am using a utility called Karabiner to map the right "opt" key to numeric-keypad "enter" key... which minimally allows me to create markers...
But I really want to find a way to access all numeric numbers...
On previous 2012 laptop I did this with Fn + number keys, enter, and period.
-jeremiah
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. jessedtf Pro Tools 10 6 10-24-2012 09:42 AM
Keyboard Shortcuts on a MacBook Pro (no numerical pad)? stpete111 macOS 3 08-05-2011 09:26 AM
MacBook keyboard shortcuts JGS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-26-2008 02:30 PM
Keyboard Shortcuts-Apple Thin Keyboard Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2008 03:17 PM
Keyboard shortcuts with foreign keyboard torsig1967 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-08-2006 05:06 AM
