Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 06-12-2021, 08:35 AM
daeron80 daeron80 is offline
Default Exported Track Folders should retain contents
Proposed: when using Export/Selected Tracks as New Session..., and selecting a track folder or routing folder, its copy in the new session should have all of the contents from the source session. Can we get agreement on that? Seems kind of silly to export an empty track folder.
David J. Finnamore
Nyquist was right.
PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB
PT 2021.6 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-12-2021, 09:12 AM
Default Re: Exported Track Folders should retain contents
Yes in 90% of the cases I'd want that too. in 100% of all cases with basic folders for sure.
However it can be useful to export just routing folders without the contained tracks if someone just needs the channel strip setup but not the audio tracks, so best would be to get check-boxes like "include contained tracks" in the export session dialogue box I think.
Or a logic like: When the folder is closed and exported, do all if the contained.
But when the folder is open just export what I selected.
Might be too confusing for people that don't read manuals so it might seem like a bug, but just a thought.
F.
PTHDn 2021.6 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 06-15-2021, 09:29 AM
ooo, I like that.
David J. Finnamore
Nyquist was right.
Old 06-15-2021, 12:30 PM
One question that may matter here is: what will happen with the exported session? If its going to another PT user for editing or mixing, I would be inclined to export without any folders. Why(a great question), because the next engineer might not want any folders, or may want a very different layout as me(or you). when I send a session to someone else, I tend to strip it down to include only what they NEED(which means, I remove track folders, groups and all "non-standard" routing(which means all tracks will be feeding a single main stereo output). When I receive sessions that have track folders and fancy routing, I spend the first 30 minutes or so just removing all that so I can get down to the job without burning time trying to decipher someone else's workflow(which I may or may not like) or figuring out their routing(especially if buses are not named)
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 06-15-2021, 01:41 PM
Sure, I would ask the next guy down the line what he prefers. My situation involves creating composing templates from which I want to export sections. E.g., orchestral template with all orch instruments plus piano, pads, and sub synths. I go to write a piece for brass only, so I want to export the masters, busses, and the brass folder to a new session. Bit of a waste of time to have to open the brass folder and select everything inside it, too.
David J. Finnamore
Nyquist was right.
Old 06-15-2021, 05:13 PM
Sounds to me like you are doing this backwards. Here's a couple of options:
#1-save your template session as a normal session. Create a new session and import only what you need from the template session.
#2-save as a template. Create a new session FROM that template. Delete whatever you don't need.
#3-create Track Presets for each scenario and call those up as needed within any session(even a blank one). Remember that Track Presets can actually be a set of tracks and not just a single track
Old 06-16-2021, 12:50 AM
gugu gugu is offline
Completely agree whiting the OP ...
And I'd say the same thing when importing folder tracks
gugu
Old 06-16-2021, 06:14 AM
sleiweke sleiweke is offline
An option in the "save session as" dialog would be nice. A box that we can check to export folder contents would be perfect for me.
sleiweke
Old 06-16-2021, 07:07 AM
Good thoughts. I started out trying #2, and it may turn out to be the best option given the current feature set. But it's really cumbersome with a Spitfire based orch template that contains dozens of folders with dozens of tracks in each, including ready-to-use stem tracks. The way they lay things out is with separate inst tracks for longs, shorts, and alternate articulations. The strings have four tracks per part, and they have a set of leader tracks in addition to groups. That's 40 inst tracks for BBC SO strings alone, plus several specialty string instruments, plus their reverb and fx chains. I love that as a composer. But as an engineer, it's a lot to deal with whether I'm selecting some or all those tracks for deletion.
I've tried #1 a few times but it's more cumbersome because the selection process is more difficult in the import dialogue, especially when selecting several discontiguous sections with dozens of tracks in each.
#3 - I can't imagine dealing with a list of around 200 track presets and recalling a a couple dozen of them one by one.
Honestly, if I could keep the folders closed in my template, and export only the folders I need, it would be a huge time saver.
David J. Finnamore
Nyquist was right.
Old 06-18-2021, 05:20 AM
Sonopolis Sonopolis is offline
+1
Freezing A Folder Track Does Not Freeze Its Contents lesbrunn Pro Tools 2020 37 05-08-2020 08:05 AM
Track Folders Are Here .. ! TrentWilliams Pro Tools 2019 65 01-25-2020 04:06 PM
What are track folders, and what is the magic therein? moshuajusic Pro Tools 2019 10 12-14-2019 05:12 PM
Easiest way to add vocal sample of different tempo to the track and retain pitch? chumbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-14-2008 09:05 PM
track folders vikingbrother 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2005 07:45 PM
