Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 06-11-2021, 07:01 PM
basslik's Avatar
basslik basslik is offline
Default Custom installs ? (plugins&instruments)
I was wondering, and I don't think I've ever read or come across this concept, except perhaps samples on a separate drive.
Anyhow I'm doing a fresh reinstall and a popup came up regarding the custom install of AIR instruments.
Are they folks that actually use a separate drive for plugins and instruments when installing Pro Tools.
I'm aware some keep samples separate? THANKS
MAC PRO 2010 5,1 3.46hex 128ram - MOJAVE - PT 2020.3.1 / 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
Old 06-11-2021, 08:57 PM
Sardi Sardi is online now
Default Re: Custom installs ? (plugins&instruments)
You can’t (well....) install plugins to anywhere but the default location.
Just install as normal and move the libraries to a seperate drive. The installers take the guesswork out of everything. Just follow the prompts unless you don’t want to install the VST/AU components. Then do a custom install and deselect those options.
Old 06-11-2021, 09:18 PM
unkJE's Avatar
unkJE unkJE is online now
AIR Installers prompt for the Samples (BIG Files) location
If you haven’t already, create a Folder (for all of your Samples) on your Samples drive called
Sound Libraries
Create a Folder in Sound Libraries called
AIR Music Technology
Create a Folder in AIR Music Technology called
AIR Content
Create separate Folders in AIR Content for each AIR Instrument
For example, locate the large Mini Grand BIG File here:
Samples drive>Sound Libraries>AIR Music Technology>AIR Content>Mini Grand
Latest AIR download links:
https://duc.avid.com/showpost.php?p=2601770&postcount=1
Installing Strike 2:
https://duc.avid.com/showpost.php?p=2601791&postcount=2
Pro Tools 2021.6 & 12.5.1 HD - Studio One 5.3 Pro - Win10 64 Pro – Lenovo W520 ThinkPads (Type 4276-37U) & 433830U Docks – SSDs Samsung 860 Evo & 2 T5s - Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 06-11-2021, 09:38 PM
basslik's Avatar
Thank you both. Now since there's much debate on APFS. Should I format the sound library APFS or Extended Journaled ?
Old 06-11-2021, 10:19 PM
I keep my external drives as HFS+ only because there are still no drive repair/optimisation utilities that work with APFS.
The other reason to keep them in HFS+ is if you plan on sharing the external drives with machines running older versions of macOS.
Old 06-12-2021, 03:42 AM
Ben Jenssen's Avatar
My understanding, although limited when it comes to techninalities of this is; APFS for SSDs and HFS+ for spinners.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command 8, SSL UC1, iPad Avid Control.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Old 06-12-2021, 03:48 AM
basslik said nothing about using an external drive for samples. If he's using an ssd and it's internal go with APFS.
Jack
QAPLA!
Old 06-12-2021, 04:31 AM
Ok. He may have a tower with multiple drive bays. You’re right. I have no idea.
Point number one still stands though. There are currently no drive utility applications that can repair APFS formatted drives. If that doesn’t bother him, then sure, no problem. It does concern me and is why all my drives aside from my boot drive remain HFS+.
It’s worth mentioning as a lot of people aren’t aware of that current limitation. Utilities like DiskWarrior have rescued many a drive for myself and colleagues.
Old 06-12-2021, 07:13 AM
basslik's Avatar
Thank you all for your valuable time.
System, Mac Pro 4,1>5,1 bootrom144
I'm reinstalling everything on a spinner and plan on cloning everything to a faster drive, and in which order the ones should be system drive, samples and recording drive.
I would like to be able to switch drives to a older OS for certain things and HFS+ would be practical I would imagine.
Combination please, system drive, samples drive, and audio recording drive config?
Here's what I have to clone system drive.
1. Single Samsung Evo Plus M.2
2. OWC Accelsior PCI
3. OWC SSD in slot bay
4. Newly acquired I/O Cest 16x2 M.2 <<<( I gather to benefit speed use 16x slot
Thank you.
Old 06-12-2021, 09:41 AM
Default Re: Custom installs ? (plugins&amp;instruments)
If you look at basslik's sig you'll see he has a 5,1 Mac Pro so that's definitely a tower. Still not having a repair utility for APFS drives isn't good but nothing one really needs to worry about as you'll have less issues with ssd's than spinners.
Jack
QAPLA!
Elaborated: Custom Organize Plugins Menu hatepop Pro Tools 12 0 12-27-2015 04:48 PM
FS: UAD 2 OCTO PCIe Custom with a lot of plugins HolB Buy & Sell 2 12-07-2014 11:06 AM
Pro Tools Installs but plugins don't! basskater87 Pro Tools M-Powered (Mac) 6 06-24-2010 01:39 PM
Newbie question about custom virtual instruments Dakota281 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-09-2010 02:39 AM
Tdm 6.4 plugins and instruments maddogz Tips & Tricks 2 08-20-2009 06:05 AM
