Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 06-10-2021, 11:56 AM
Concentrix Concentrix is offline
Default iPad Avid Control problem connecting.
I cannot get the Avid Control app on my iPad to connect via EuCon. I have:
-- Made sure I have the latest versions of all software.
-- Re-started the computer and iPad a number of times.
-- Confirmed that both my Mac and iPad are connected to the same 5GHz wi-fi network.
When I open Avid Control on the iPad, it shows up in the All Surfaces column. As soon as I add it to My Surfaces, it disappears from both. I click Show Info and get the "having connection issues" message. I do what the prompt suggests...same result.
Any suggestions are welcome!
Old 06-10-2021, 12:52 PM
Default Re: iPad Avid Control problem connecting.
Well, for those who may be having the same problem...I've solved mine.
Our Wi-Fi router is an Airport Extreme. A look inside the network settings revealed that incoming iPv6 connections were blocked. When I unblocked them, voila.
Cheers, everyone.
Old 06-11-2021, 07:23 AM
Check that. I had Control working yesterday afternoon. This morning...same problem.
Now I'm stuck. Any suggestions anyone?
Thanks!
Old 06-11-2021, 09:22 AM
EddieJones's Avatar
That router is known to cause issues.
Old 06-11-2021, 10:28 AM
That's what I was afraid of. Looks like it's time for a new wi-fi router. Thanks!
Old 06-13-2021, 05:31 AM
brandonwong brandonwong is offline
How do you go about checking that it was blocked and go about unblocking it?
Old 06-13-2021, 07:18 PM
IP settings are in the Airport Utility app. But as I mentioned, after changing the setting it only worked briefly. I ended up buying and installing one of the Avid recommended WiFi routers and it all works now.
Does PT First support Avid Control iPad app? atkeyboards Pro Tools | First Discussion 4 02-13-2021 03:17 PM
Avid Control with iPad on Windows 10? atticmike Pro Tools 2020 3 12-04-2020 09:53 AM
S3 + iPad Running Avid Control priorytools Avid S1, S3, Dock and Control 0 06-07-2020 05:13 AM
Avid Control iPad soft keys disappear difonzo Avid S1, S3, Dock and Control 11 04-14-2020 03:58 PM
New Avid Pro Tools Control for iPad nst7 Avid S1, S3, Dock and Control 261 10-13-2015 12:33 PM
