Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 05-12-2021, 03:44 PM
Stamak Stamak is offline
Default Big Sur 11.3 bricks Avid Control App and EUContrl
Until today Avid Control (on I Phone 7plus -IOS 14.4) worked with EuControl
without a hitch in Pro Tools 2021.3.1
I updated my MBPro to Big Sur 11.3 and now the Avid Control App cannot connect to Pro Tools and EuControl version 2020.11.1 will not start.
''EUCON network connection not found''.
My Apogee Control App works fine with Apogee Ensemble so the Wi-Fi is OK.
Question : Is this a software problem with the Avid Control App or
EuControl or is Big Sur the cause of the problem?.
Any ideas how I can solve this.
Many Thanks
Stan McKee
Old 05-12-2021, 05:57 PM
Ben Jenssen's Avatar
Default Re: Big Sur 11.3 bricks Avid Control App and EUContrl
Big Sur is a big update. Many things change. You can't do a jump like that and expect everything to work.
I spent ten days trying out PT on a M1 w/bigsur, but went back to the setup in my signature.
How you solve this? You restore your catalina backup.
Sorry for being unhelpful.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command 8, SSL UC1, iPad Avid Control.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Old 05-13-2021, 06:45 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Both EuControl and the Control App are qualified with Big Sur.
https://avid.secure.force.com/pkb/ar...ig-Sur-Support
It may be worth uninstalling and re-installing. Depending on what OS you were updating from, there are several System Preferences that require permissions being granted.
If the uninstall/re-install doesn't work, I'd suggest opening a support case so we can dig in a bit deeper.
Mark Corbin
Eucon Surface & Pro Tools Product Champion
Audio Services Supervisor
For immediate assistance:
S6 Support - 888-456-3444
Venue Support - 650-237-1711
Euphonix Support - 650-237-1604
Pro Tools Support - 650-237-1700
Old 05-13-2021, 08:54 AM
EddieJones's Avatar
As Mark says do a full Uninstall of EUCON (using the EUCON installer and checking remove all Apps and remove all prefs) restart and re-install.
Old 05-13-2021, 02:29 PM
Hello Mark & Eddie,
Many thanks for the quick response to my question about Avid Control.
I uninstalled EUCONTROL and then installed it as you suggested and the app is now working fine. The app speeds up the workflow tremendously when working in Pro Tools.
Best
Stan McKee
Old 05-14-2021, 06:58 AM
MCorbin's Avatar
Good stuff, glad to hear!
Mark Corbin
Old 06-11-2021, 12:54 PM
SquishyCat SquishyCat is offline
Alas, I've uninstalled/reinstalled on 11.4, but it still doesn't expose the MIDI ports or allow Logic Pro to see my Control or Mix controllers. What are the privileges these need?
I've been using them to control a lot of apps, but all of that is gone, now. I really love the convenience of these when they're working, so any advice would be appreciated.
Old 06-14-2021, 09:54 AM
EddieJones's Avatar
Just to check you are not trying to connect Logic via MIDI ports?....Logic is native EUCON
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? XJENSEN Avid S1, S3, Dock and Control 1 02-14-2020 06:22 AM
AVID / Digidesign ICON D-Control 32 Fader Pro Tools control w/ Surround Panner legasafe Buy & Sell 3 07-20-2019 09:54 AM
Waves WLC Update Bricks Pro Tools... The Weed Pro Tools 12 28 04-14-2016 02:37 AM
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
