Old 04-22-2021, 04:57 AM
Wellnitz Wellnitz is offline
Default Re: 2021.3.1 issue
+ 1
this is very annoying.
Furthermore, a sample rate conversion from 24 to 25 is no longer possible.
regards
Jochen
Old 04-22-2021, 06:43 AM
daeron80 daeron80 is offline
Originally Posted by Wellnitz View Post
[snip]a sample rate conversion from 24 to 25 is no longer possible.
Frame rate conversion?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-22-2021, 09:51 AM
mydog_norm mydog_norm is offline
I had the same issue last week after doing a save copy in session for backups. After I make the back up at the end of the session, I open the new session to make sure it works. But every session that I backed up, would not open. After restarting they would work, but the next day they would still lock up when the video was loading. I moved back to 2020.9.1 and everything went back to normal. Would like to know a good resolution to this.
Old 04-23-2021, 10:49 PM
iosugonzalez iosugonzalez is offline
Same Issue for me .
Enviado desde mi iPhone utilizando Tapatalk
Old 04-26-2021, 11:36 AM
DavidCaporale DavidCaporale is offline
1m1, is your issue happening when the PT session has come from another system; in other words the video file will be linking to a folder that doesn't exist for you, and PT sees it as missing?
If so, I have the same issue with 2021.3.1. Rolling back to 2020.12, the issue goes away.
Check out Users/Shared/AvidVideoEngine/Avid FatalErrorReports
You'll see a log file labeled AMALogger and dated. Open that up and you'll see AvidVideoEngine going through a list of media containers for each video file you have in that session. Then it'll return a "Warning: Registered matchings were not found"
Not sure what this means. Hopefully the mods or the Video Engine Dev Team can shed some light.
  #16
Old 04-26-2021, 12:00 PM
its2loud its2loud is offline
I just experienced this with a session coming from 2020.5 and trying to open on 2021.3. Session hangs on loading the video files.
  #17
Old 04-27-2021, 08:14 AM
dansoundmix dansoundmix is offline
Default Re: PT 2021.3 Hangs on opening old sessions with Multiple Videos
I ran into this issue again, and now I'm having the same issue as David. The video engine re-initializes and opening takes a really long time. I eventually get a message, "This session contains media that is not supported possibly due to a missing CODEC" which is not correct.
I'm trying to pull elements from an older job and this is very aggravating.
This has to be fixed in the next release as 2020.12 had too many bugs (video engine) making day to day work, unbearable.
Dan
  #18
Old 04-27-2021, 01:14 PM
It is the same issue as discussed on the thread below.
http://duc.avid.com/showthread.php?t=415008
  #19
Old 04-27-2021, 02:50 PM
Ehof Ehof is offline
I'm having the same issue. 20 min wait time "Restoring Video Files" 2021.3
  #20
Old 04-28-2021, 08:31 AM
walter rohrbach walter rohrbach is offline
+ 1
regards
Jochen
+1 not only annoying but very boring.
Opening a PT session pre 2021.3 it takes forever
Walter
walter-rohrbach.com
2021.3 constant hangs huzzam Pro Tools 30 04-01-2021 12:14 PM
crashes on opening sessions with video Anibal Pro Tools TDM Systems (Mac) 0 02-25-2011 09:41 AM
PT hangs when opening sessions Borfus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2011 05:39 PM
Pro Tools 7.4 hangs when opening buzzedit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-07-2008 09:52 PM
PT 7 Hangs while opening a session Baseman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2006 05:15 AM
