Old 02-27-2012, 03:40 PM
ydoolz ydoolz is offline
Default Pro Tools 10, random static on playback
Hello Everyone,
So I was working like normal today in Pro Tools 10, just doing some editing, when I tried to use an AudioSuite plug-in (EQ 3 7 band & TCE) each clip (region) when crossed by the playback marker during playback, would play VERY LOUD STATIC over any clip. (Not static from the speakers BTW)
• I tried closing & restarting Pro Tools, negative.
• Restarting Computer, negative.
• Installing 10.0.1 update, negative.
I opened other sessions, they work fine, for whatever reason the session I was working on today for about 4 hours now plays back only static, even if I go to an earlier save that originally wasn't having an issue.
I have to deliver my work by tomorrow and am trying to avoid re-installing Pro Tools if possible.
Anyone else had or having this issue? Any help would be appreciated. Thanks in advance.
Old 02-28-2012, 08:15 AM
Default Re: Pro Tools 10, random static on playback
I also tried deleting the Pro Tools preferences and Digi Database as well. Still negative.
Old 02-28-2012, 08:23 AM
Southsidemusic's Avatar
Hey
We had that EXACT thing the other day! I was so pissed and frustrated and reinstalled as you but nothiing. Then I looked at every track and closed every plugin on each track and wooohooo!!! Working again. Our exact plugin that screwed up was a few API eq's and as soon as the were removed and replaced by the same plugin all was well in the world again 😃 We had the same on our earlier saved versions of ONLY that song but try to close the plugins from the 1st track and keep trying after each removed plugin and I promise you'll be ok 😉
Cheers
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-28-2012, 09:01 AM
Thanks for the heads up. Although it didn't work for me.
What was weird is if I made all of the tracks inactive except for one in particular, it isn't staticy. This problem is terrible.
Old 02-28-2012, 09:10 AM
Alright I found a way around it. I had to remove all the plug-ins, import all the tracks "Copy" not "Link" into a brand new session. What a pain.
Old 11-25-2012, 07:41 PM
melvindesk melvindesk is offline
i have same problems also, i guess it wasnt from tha API coz i tried play some songs from itunes and having the same problem.
Old 11-26-2012, 12:31 AM
sdbrotastic sdbrotastic is offline
I have been having the same problem. I will play a session and it will sound staticky (did I spell that right?). I thought it was my interface, but I opened itunes and it didn't do what it did on the pro tools playback. It didn't do that until I downloaded 10.3.2
Apple Imac 2.7GHz Quad-Core Intel Core i5, 4GB Ram, OSX 10.8.2, Apogee Ensemble, Pro Tools 10.3, CUBSE 6.5, API LUNCH BOX, CLASSIC API VP312, CLASSIC API VP26, Drip Electronics Pultec, Hairball Stereo 1176 revD, Audio Maintenance EZ1073, Adam A7X, WAVES PLUGINS, Slate Audio Plugins
Old 10-04-2015, 05:14 PM
iammietig's Avatar
iammietig iammietig is offline
I have the same issue but, only when I try to use CLA Vocal plug-in... any suggestions? Other than not using the plugin? I really like it.
Sandra
Model : Lenovo H215 10029
BIOS : Lenovo D2KT21AUS 03/12/2010
Total Memory : 8GB DIMM DDR3
Processor : AMD Athlon(tm) II X2 215 Processor (2C 2.7GHz, 2GHz IMC, 512kB L2)
Socket/Slot : AM2r2/AM3
Video Adapter : NVIDIA GeForce 210 (2CU 16SP SM4.1 1.24GHz/1.49GHz, 1GB DDR3 270MHz 128-bit, PCIe 2.00 x16)
Storage Device: SAMSUNG HD300LJ (300GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 279GB (C:)
TSSTcorp CDDVDW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
HELP! static bursts random - ignited in playback Mr.Smear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-14-2012 05:45 PM
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 08:59 AM
Random static noise upon playback boynigel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-24-2010 10:31 PM
Random static noise during playback/bounce randomanton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-18-2010 09:52 PM
Random (intermitent) bursts of static during playback Knightbus Pro Tools M-Powered (Mac) 17 05-19-2009 08:54 PM
