Old 11-07-2010, 08:02 AM
midi sordino midi sordino is offline
Default VI's with PT 9
Anyone using East West PLAY engine with PT 9? Or Vienna Ensemble Pro with VI's?
Old 11-07-2010, 11:48 AM
Eric Lambert's Avatar
Default Re: VI's with PT 9
Vienna/PT9 here. What's your question?
Old 11-08-2010, 02:29 AM
Thanks for the reply. Was just looking to see if EW PLAY and Vienna Ensemble Pro are currently compatible with PT 9. Have since found out that they are (Avid Support/ Vienna forum).
Any problems with any VI's or plug-ins? Particularly interested in Altiverb 6 and Waves stuff...
Old 11-08-2010, 08:55 AM
DigiTechSupt's Avatar
Yes, they are - just make sure you're using THE latest version of either one.
Avid Audio Tech Support
Support FAQ
Old 11-08-2010, 03:56 PM
Thanks. I've since downloaded PT 9 and all is well. Fantastic upgrade. Very well thought out. Great job Avid.
Old 11-08-2010, 04:34 PM
Daviskenn Daviskenn is offline
I'm running the first gen Xeon Dual 2.66 Mac Pro with 5 gb RAM...I just upgraded to PT9 and I'm getting a lot of Running out of memory messages when running pretty intensive VI's. I've got 4 instances of Amplitube 3 (on eco) and Superior Drummer 2. When I try and run Trillian, it won't even load up - and in fact has crashed 9 several times. I'm pretty sure I've run the equivalent in Cubase 5...I don't expect to run all of this glitch free at 128 buffers, but I would think I should be able to at least track stuff with only 5 tracks. BTW - where the hell is a freeze function?!! Anyway, I know I could build the drums, bounce to audio and repeat...but I want to be able to build on the fly and not have to commit to arrangements and sounds before I know what I want to do.
Buffer size: (won't load Trillian Samples even at 1024)
Host processors: 2 processors
CPU Usage Limit: 85%
Ignore errors unchecked
Any suggestions for better performance?
Old 11-08-2010, 06:00 PM
For starters check your OS is 10.6.2 or higher. Also Update all third party plug-ins and make sure they're compatible, e.g. Waves plugs need to be version 7 etc.
How do you use VI's in PT9 with an MPC? Myestro Virtual Instruments 0 04-24-2011 01:13 PM
50 Spectrasonics VI's, 50 NI VI's and 50 structure all in one pro tools session crizdee Pro Tools TDM Systems (Mac) 11 04-03-2010 09:03 AM
64-bit VI's Naga Virtual Instruments 2 10-28-2009 06:24 AM
Using VI's that come with PT8 in my TheStriker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-28-2009 04:44 AM
USing 2nd Mac for VI's RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-19-2008 02:21 PM
