Old 11-30-2008, 09:18 PM
grimepoch grimepoch is offline
Default Multiple Interfaces?
Hello!
I have tried to search for this answer, but do not seem to find it. First, I am a new user to ProTools land. For Post Production work, I just bought a Digi Rack 003 in anticipation of PT8 and the complete pack so I can do surround mixing.
I just finished a project that started in Final Cut, then Sound Track Pro, then Logic and then finally into Digital Performer 6 where I finished it. Needless to say, this was a painful process.
That said, I would consider myself and expert with DP6, Logic 8 and unfortunately Sound Track Pro. While I plan on continuing to use Logic for music writing (as I really like the Midi implementation), I am VERY distraught over audio file work in DP and Logic. For long projects they are just...just too full of bugs and limitations that caused countless hours of rework and frustration.
So, one of the things I can do with DP or Logic is use multiple interfaces. Yes, I am aware of the ADAT port. Currently in DP I can use my 2 896HDs with an Apoggee Rosetta 200 hooked up to one of them. I use a lot of inputs due to my collection of Hardware Synths.
Can I do this with PT8? Can I select 2 two Digidesign interfaces?
I externally sync everything with a Lucid GenX6 wordclock (which works great).
Ultimately, I'd like to get rid of the 896HDs if I can get that kind of operation with PTLE, but I also realize I'd be able to use multiple 003s just as the 896s in the other applications.
Rick
Asylum Studio Productions
Old 11-30-2008, 09:49 PM
Default Re: Multiple Interfaces?
Sorry, the answer is no. Protools LE can only work with one Digidesign audio intertface at a time.
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.5.1 running Protools 2021.6
Old 11-30-2008, 10:15 PM
Thanks for the update. Well, I am still doing my music in Logic where I need all the instruments so I think that will be fine.
I will just borrow a Digi 003 from someone locally and try them in aggregate mode in CoreAudio and make sure that works with both DP6 and L8. I might be good to go then.
Old 12-01-2008, 06:29 AM
andydunham andydunham is offline
Don't know if this will help or not, but I use LP 8 with a Digi 003 and a Motu 8pre thru ADAT and it works great!
Old 12-01-2008, 06:30 AM
With Core Audio, I mean.
Multiple interfaces in pt9 HD? muddboy macOS 7 05-12-2013 11:23 AM
Multiple interfaces Julia B Pro Tools M-Powered (Win) 3 06-22-2011 08:07 PM
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
multiple interfaces with pt9 rivetheadsound Pro Tools 9 22 04-21-2011 10:33 AM
AES/EBU on multiple 96 interfaces Robin Reumers Pro Tools TDM Systems (Mac) 0 10-12-2006 09:41 AM
