Old 01-01-2008, 07:17 AM
bigcow bigcow is offline
Default MP3 Option
I just reinstalled PTLE 7.3 on my new computer (Apple Dual 2.7 GHz PowerPC G5/OS 10.4.11)
and visited the Digistore to access the MP3 option I purchased last year and my receipt and
authorization code are there but the installer is no longer available to download.
Please advise on how I can reactivate this option.
Thanks.
ProTools LE 8.0.3
iMac
Dual 2.5 GHz Intel Core i5
4 GB RAM
1 TB Seagate External HD
Old 01-01-2008, 08:38 AM
Phil Ogden Phil Ogden is offline
Default Re: MP3 Option
The mp3 option should be available under a custom install of 7.3. Run the PT 7.3 installer again but uncheck everything you've already got and check the mp3 option. You might want to remove any existing mp3 Codecs first.
Here's a link for the mp3 guide,
mp3 option guide
http://www.myspace.com/philogg
Old 01-01-2008, 09:20 AM
Thanks. I removed the mp3 codecs and it installed successfully.
When I select the mp3 drop down in either bounce or export and
then hit export, all I get is a blank PT dialog box with an OK button.
Nothing happens.
ProTools LE 8.0.3
iMac
4 GB RAM
Old 01-01-2008, 11:09 AM
MP3 option is not allowing me to authorize (Authorize tab is greyed out), since upgrading to Pro Tools 7.0.
Authorizing MP3 Option for Pro Tools Mac OS X
Remove the MP3 folder from the Mac HD\Applications\Digidesign\Pro Tools\Codecs folder
Trash all databases and preferences (move the Digidesign Databases folder located on the root level of all drives mounted on the computer to the trash; also, in the Mac HD\Users\(Your User - House Icon)\Library\Preferences folder, delete the com.digidesign.ProTools(LE).plist, DAE prefs folder, DigiSetup.OSX, and Pro Tools V.x(LE) Preferences files).
Empty the trash from the Finder menu.
Run the Pro Tools installer from your current Pro Tools version's installation file or CD and choose ONLY the MP3 Update (not the Demo). This should place the MP3.bundle back into the MP3 folder in your Codecs folder. If it does not, restart and run the installer again.
Update your PACE files and launch Pro Tools (see link below)
Once you choose to bounce as an MP3, you should see the correct Authorize window (make sure you have your code ready - if you choose to cancel, you'll have to restart and relaunch Pro Tools to authorize again).
http://www.paceap.com/dldrvr.html
Old 01-01-2008, 11:31 AM
Thanks. But I saw this posting earlier and
followed the directions. Still no go.
The thing is, I've had the option for
a year and a half and have been using
it with PT LE 7.3
The only thing I didn't do is update my PACE
files. Not sure what that is.
Please advise.
Thanks.
ProTools LE 8.0.3
iMac
4 GB RAM
Old 01-01-2008, 10:02 PM
WinstonPaul WinstonPaul is offline
about MP3 option ... somebody knows if it is available in PL7.4, when U just downloded the new version?
Old 01-02-2008, 02:17 AM
It's available from the Digi store.
Old 01-06-2008, 02:08 PM
Followed the instructions from tech support below plus everyone else's instructions in this
thread and still getting a blank PT dialog box with only an OK button
when either export or bounce is selected for the mp3 format.
I purchased the option in March 2006 and have been using it
with no problem until I upgraded my computer from a G4 running
10.4.11 to a G5 running the same OS. This is getting very frustrating.
Any suggestions?
Tools\Codecs folder
again.
again).
ProTools LE 8.0.3
iMac
4 GB RAM
mp3 option simplemix Pro Tools TDM Systems (Mac) 2 03-22-2007 02:02 PM
MP3 Option-Demo Expired-No option for aut. code desdichadisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-10-2006 01:24 PM
HD with AV Option XL digiengineer Pro Tools TDM Systems (Mac) 2 07-18-2002 07:24 PM
AV Option or AV Option XL with Transoft Fibre potatohead Post - Surround - Video 5 08-06-2001 10:24 AM
AV Option Fan required for AV Option|XL too? Samhein Post - Surround - Video 3 08-29-2000 05:45 AM
