metering?
I have started to experiement with EQ and compression and I want a way to actually monitor the db levels of what I am doing. Should I just be using something like the free Bomb Factory meter plugin? If, what setting? Also, how do I handle calibration?
Thanks |
Re: metering?
Just be sure that under "options" you de-select "prefader metering"
Re: metering?
Does anyone know what this can't be done directly within Pro Tools, without using an RTAS plugin? I am not complaining that you can't, I am just curious because I thought it was important. Basically, I am sure there is a good reason for it, so I want to know what that reason is.
Re: metering?
Hello,
what exactly do you want to meter? dbu dbV dbspl dbL ? not forgetting that the digital 0 dbu is about 20dbu higher than analogue! A complicated subject your getting into |
Re: metering?
I suppose what I want to do is verify my mixes are as loud as they can be. As far as what I what type of db I am interested in, I am not sure.
Re: metering?
What you need to look up is the difference between peak level and average level, thats what gives you your apparent "loudness", this is where compressors come in. 120 dbL for 20ms wont appear as loud as 80 dpL for 1s.
Heres a free metering tool that might help you. http://www.sonalksis.com/index.php?d...§ion_id=14 Dowload "Sonalksis FreeG (Full version free download) v1.08" |
Re: metering?
Hello again,
I just started reading this thread and thought of you question. http://recforums.prosoundweb.com/ind...t/15038/13122/ I think dbfs is the right term |
Metering? | Creap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-17-2009 10:53 AM |
Metering | Soundtrack2life | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-31-2008 07:20 AM |
Metering?? | ThomasPMusic | VENUE Live Sound Systems | 10 | 03-31-2008 01:36 PM |
Pre-Fader Metering vs Post-Fader Metering | teacherman | Pro Tools TDM Systems (Mac) | 3 | 01-29-2008 07:33 PM |
Metering | Nika | Pro Tools TDM Systems (Mac) | 11 | 07-28-2003 09:16 AM |
