Old 12-19-2006, 07:32 PM
roberts roberts is offline
Default 7.1 bug back in 7.3
Just updated to 7.3cs1
Change buffer from 256 to 512 = C R A S H
100 % repeatable
7 Card HD Accel, Magama 64 bit chassis dual 2.5 G5 6 GB RAM
OS 10.4.8
Fixed in 7.2 back in 7.3 cs1
100 % repeatable
Old 12-19-2006, 08:01 PM
uno1234 uno1234 is offline
Default Re: 7.1 bug back in 7.3
are you using an mdw EQ? This is well documented.
Old 12-19-2006, 09:31 PM
Nope
Old 12-20-2006, 09:06 AM
Are you using an Expansion HD? I had this crash once today but couldn;t repeat it.
Old 12-20-2006, 11:04 AM
DigiTechSupt's Avatar
Can you provide more details and/or reproduceable steps?
Does it make any difference if a session is open or not when you change the buffer?
What are your voice allocation settings when this occurs?
Is the problem repeatable with no plug ins in the system?
Can you confirm the model number of your chassis is either model P7R464 (current), or P7R464-D1 (discontinued)?
Avid Audio Tech Support
Support FAQ
Old 12-20-2006, 11:26 AM
Mauro371 Mauro371 is offline
I am also having problems like yours. Any change in the Playback engine settings will cause a crash. I am running on a Magma chassis as well.
I did find the following. If I open a session in which all voices have been allocated to 1 DSP, the session runs perfectly fine. If the same session is saved (in another system) where voices are assigned to more than 1 DSP, and then I try to open that session and run it with more than 1 DSP, it crashes. If I am able to open it using 1 DSP, then it runs.
Also, it crashes without having to open a session. If I open ProTools and then try to change the Playback Engine to using more than 1 DSP, it crashes.
I don't remember having this problem with 7.1, but it sure is here with 7.3cs1.
Old 12-20-2006, 11:45 AM
We are unable to reproduce this. Can you provide more info about your system specs and steps to repro?
Support FAQ
Old 12-20-2006, 12:28 PM
I had this crash with a session open, and 3 DSPs allocated for voices. I was not able to reproduce it when opening the same session after restart. It seems like a plugin problem in the same way the MDW EQ causes playback engine crashes. It is not the same type of crash as that though. With this crash you get no error message, you just can't hit "ok" in the PB engine dialog. I didn't get a spinning beach ball though. I had the DSP allocation window open at the time, and the DSPs where the voices reside were empty. Upon force quit of Pro Tools, the lights on the 192s were blinking.
When you're referring to the model number of the chassis, are you referring to the Digidesign/Magma chassis, or the Digidesign 6 Slot Expansion HD? I have the Expansion HD, not sure where to find that number though.
Old 12-20-2006, 01:52 PM
Found a MDW Plug-in on a hidden active track. It is only repeatable with the MDW Version 2 Plug-in
Old 12-20-2006, 02:24 PM
asylanten asylanten is offline
I have the same trouble
well I've worked with midi in a instrument track, then after recording when I tryied to rise the buffer setuo protools crashed, this happen sometime, but in this case no plug in were open
Mpowered 7.3 cs1
Should I back back all files from my internal hd to my OWC external firewire800 hd? moya83 macOS 1 11-12-2012 06:36 AM
2 monitors back to 1 - can't get video back from right screen simon hunt macOS 5 10-09-2012 05:37 PM
Digital feed back on play back after Bounce drew88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-12-2005 01:18 PM
Back up system folder on back up drive? Mick F. Cantarella Pro Tools TDM Systems (Mac) 1 12-24-2002 09:15 AM
Masterlist also used as back to back mixed by a Dj "list"? Eric Maijs Digidesign Hardware & Software 0 04-09-2000 06:50 AM
