Old 05-25-2021, 03:12 AM
garret garret is offline
Default Q for Jeff. Master Module Channel Strip on S4
Hi Jeff
I was just wondering about the single fader channel strip on the S4. It has a swap button as opposed to the regular focus button. Also it has a rotary encoder which seems to be inactive. I am assuming these are all relevant for the S6 only as it is the same Master Module used for both consoles?
Thanks
Garret
IMDB
Old 05-25-2021, 04:30 AM
creativecontrol's Avatar
Default Re: Q for Jeff. Master Module Channel Strip on S4
Greetings,
S4 shares an Automation Module (below the Master Module) with S6. On both systems, the Swap Layer and the encoder above the Attention Fader are currently not implemented (in Pro Tools). Eddie has commented on adding both of these in various threads. I believe the Swap Layer is of higher priority - but I will defer to him regarding development. Custom Knobs are next.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-25-2021, 05:23 AM
Thanks Jeff!
IMDB
Old 06-08-2021, 10:57 AM
EddieJones's Avatar
We are working on the Swap feature for later this year. We are also looking at adding the EUCON assignable knob feature to Pro Tools (that Nuendo, Logic and Pyramix have). This will mean that the single knob on the Master Module will follow where ever the mouse is in PT...so if you are controlling a knob on a plugin with the mouse and need finer control you will be able to reach over and use the knob. You should also be able to lock the knob to a control too.
Old 06-08-2021, 02:38 PM
Sounds cool Eddie. Thanks!
IMDB
Old 06-08-2021, 03:50 PM
basehead617 basehead617 is online now
Thanks Eddie -
For those of us that have not used surfaces that implemented this, can you explain what the idea of the Swap layer is?
Old 06-09-2021, 09:42 AM
EddieJones's Avatar
Currently Layouts are 2D. they are 1 deep by X wide(settable in prefs). For the Swap feature we will make it 3D. So you will be able to set not only the number of tracks in a Layout width ways but also between 1 to 4 deep too.
The Swap button on the S4 master Section will cycle the Strips between Layer A , B, C or D (depending on how many you set). On S6 you can do this as well as swapping individual Strips.
Old 06-09-2021, 12:45 PM
Mindboggling but very cool! Looking forward to seeing it in action.
Old 06-09-2021, 12:50 PM
EddieJones's Avatar
The S5 and the S5MC both had this but only 2 layers deep.
Old 06-09-2021, 04:19 PM
Whats a quick example use case of what Layer A -> B would change between on a single channel (or even a bank of 8), in a layout? Trying to think of something that isn't already covered by folders/vcas or expand faders..
Plugins Not Responding in Master Channel Strip Cayce Pro Tools 2020 2 11-10-2020 04:17 PM
Display Module Request - Maintain strip view/ignore expanded knob information jmattchan Avid S4/S6 4 09-11-2018 07:32 PM
Renaissance channel vs Channel Strip frenchman Tips & Tricks 1 09-20-2003 05:18 AM
Channel Strip on Stereo Master Fader stevemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 08:25 PM
Channel Strip and Master Fader fifty8th1 Tips & Tricks 5 06-07-2001 02:56 PM
