Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-16-2021, 11:17 AM
bonkmp bonkmp is offline
Default No input to Spdif
I’m using focusrite 8i6 interface on the new MacBook Pro M1 and when I try to use the SPDIF input into ProTools First there is no signal. I can record into ProTools using the focusrite preamps. I know the interface is working and accepting signal from my AD converter.
Thanks, Marty
Old 08-16-2021, 11:39 AM
Top Jimmy's Avatar
Default Re: No input to Spdif
Do you change the clock source to S/PDIF when using the S/PDIF input?
James Cadwallader
Old 08-16-2021, 12:49 PM
Yup, I've been using PT for about 16 years with the same rig, Mytek stereo AD, Digi 008, etc. and I'm exploring this because my 2008 Mac Pro is getting erratic.
I did notice that there's no I/O map available but once again spdif inputs show up and the 8i6 pres work so it appears to recognize it.
Old 08-16-2021, 01:23 PM
Top Jimmy's Avatar
Rereading your first post, I see you’re talking about First. First is limited to 4 inputs. These will always be the first 4 presented by the interface driver. If the Focusrite control app doesn’t allow for rerouting the S/PDIF inputs to 1-4, then it won’t work. FWIW, in my experience, MOTU PCIe interfaces did allow rerouting.
James Cadwallader
Old 08-16-2021, 05:30 PM
Ben Jenssen's Avatar
PT First is very limited.
There's always the 30 day fully functional demo, if you haven't already used it. You said you were exploring.
Old 08-31-2021, 05:53 AM
myster6 myster6 is offline
Thanks, Marty
i experienced the same issues with the same Interface - cost me two weeks of fumbling - no result. Too bad that there is no hint about the limitations of "First". Did you find another solution?
Old 09-01-2021, 09:39 AM
Nope, I spent quite a bit of time with Focusrite tech support and they confirmed no workaround. Since the I/O is software dependent my assumption would be the only fix would be a rewrite of the software.
11R Mic input to SPDIF out Dave Modisette Eleven Rack 0 06-14-2014 11:16 AM
SPDIF Input on 002 nwrstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-20-2008 01:04 PM
Where is my SPDIF input? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-16-2007 07:22 AM
SPDIF Input on 196 io Sync Jeremy Mix3000 Pro Tools TDM Systems (Mac) 6 02-21-2007 09:21 AM
low spdif input and other q's: pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-09-2003 10:02 AM
