Plug In Issues under PT8 - Full List with Solutions Here
If you are experiencing plug-in issues after upgrading to Pro Tools 8, then you please list the issue here.
Before you do, please make sure you have taken all the steps outlined by Digidesign prior and after installation to trouble shoot, you can find this here http://duc.digidesign.com/showthread.php?t=229829 This list is for PT8 running on Mac OS X, if you wish to start one for other version, please make sure it is listed in the appropriate part of the DUC. This will save confusion for both those listing issues and also those looking for solutions. Also remember to give us as much information as possible, MINIMUM is hardware, OS version, plug-in version and interface used. Please do not use this thread for anything other than its intended purpose. Also please make sure you use the SEARCH facility within the DUC before posting and issue, this can save you a great deal of time. Finally Digi Tech Support are working flat out to resolve issues found so far, so please be patient and also please refrain from posting emotional outbursts (however frustrated you are). Hopefully we can compile a definative list and get to solutions quickly.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Re: Plug In Issues under PT8 - Full List with Solutions Here
OK from searching the DUC so far early reports are:
EZ Drummer: Some reports of it not running and others of it showing a weird VI. http://duc.digidesign.com/showthread.php?t=234184 Latest update is that the mixer does not work, when clicking on the faders in the mixer section of EZD numbers appear and no fader action possible. Also unable to allocate separate outputs.MacBookPro 1st Gen 1.83,2gb, 10.5.5, Digi 002R, Firewire drive Superior Drummer: Slow performance. http://duc.digidesign.com/showthread.php?t=234184 Stereo Mixer and Surround Mixer: Solution here http://duc.digidesign.com/showthread.php?t=233996
Good work Russ.
Toontrack Superior 2.0.2, Overloud Breverb and TH1 would sound fine but the plugs' interfaces would not respond if you opened saved sessions in PT8...
More info please.
Issue/Plugin: Addictive Drums v 1.1.1
ProTools LE 8.0 Crashes any session unless plugin is removed from the folder. My only fix was to remove plugin - and awaiting response from XLN. Prefs, permissions, and other files did not impact this crash. Intel Mac OSX 10.5.6 4GB RAM Digi Rack 002 Last edited by GretschGuy; 12-22-2008 at 05:18 AM. Reason: error in plugin version |
Issue - Wont recognise Reason, comes up with the message - Engine not responding please check your rewire host. On 10.5.5 and using Reason 4.0.1
Well, lets say if I have a saved session that contains Superior 2, TH1, and Breverb, these plugs would play back okay, but if i open them, their interfaces would show up but not responding to any clicking... so I would not be able to change the settings on these plugs unless I close them and reopen them... >.<
The Vienna Instruments Server Interface "Show Window" does not respond to mouse rollover.
I created a new session, created a stereo Instrument Track, and inserted Vienna Instruments (VI) Special Edition. The blue VI interface appeared and I loaded a matrix. The matrix loaded and I could play it with my controller. I closed the VI interface. I clicked on the VI insert button in the Pro Tools Instrument Track. The Vienna Instruments Server Interface appears. *When I attempt to click on the "Show Window" button in order to see the VI interface, I can't. The button is "unclickable." Normally, when you rollover the button with the mouse, it lets you know you can click on it. This does not happen, and clicking on the button produces nothing.* Apple iMac, 1.83 GHz Intel Core Duo, 2 GB RAM OS X 10.5.5 Pro Tools 8 Vienna Instruments v2.0.3238 MBOX2 Pro Edit: I found that if I change the MIDI out of the Instrument Track (say, from channel 1 to channel 2), I am again able to click the "Show Window" button. If I close the VI interface, I must again change the MIDI out in order to view the VI interface again. |
Super TDM Plug ins;TC VSS3,Master X,Line 6,Sonic Solutions,Eventide TDM Plug Ins | Digitaliz | Buy & Sell | 3 | 07-26-2013 04:39 AM |
firewire issues on G5 - opinions and solutions! | Andi R | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-15-2005 04:32 AM |
Plugin list too full | JFogarty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-23-2005 04:10 AM |
LIST of PT6/HD Upgrade Warnings/Solutions | The Mink | Pro Tools TDM Systems (Mac) | 4 | 03-22-2003 09:34 AM |
Are *ALL* Dealers Charging Full List For HD Upgrade? | tech_head | Pro Tools TDM Systems (Mac) | 2 | 05-04-2002 12:17 AM |
