DIGI002r booting up issue
While I was working on a session, MAC reported that it could not access hardware for PTLE, I rebooted the 002r, disconnected and reconnected firewire connection and it came back up. Then the next day when I turned the 002r on, it booted up without any MIDI or Firewire connection lights, but after a clicking noise, they were up and everything worked. The third day, I noticed that it did the same thing, it sat there for a couple of minutes and then after some clicking, everything worked.
All my equipment is connected through a power conditioner. I was wondering if anyone else is having a similar issue, and what could I do to rectify this. Thank you Syed Dual 2.0 GHz G5 - PTLE 6.4 - DIGI002r |
Re: DIGI002r booting up issue
Syed,
Yep, it's most likely the infamous power supply - power harness issue. Call Digi tech support, I had the same exact symptoms as yours, although some units go down completely when they fail, mine was intermittent.... failing occasionally, but failing more and more as time went on. It was explained to me that this was due to the power supply putting out a "borderline" voltage. See my recent post "002R Fixed!! But, a warning...." My warantee was just about due to expire, but other users have been able to get their units repaired (when it was this problem) when thier units were out of warranty. Give them a call, and I hope it works out well for you. Hope this helps..... Dave
dave cardoza carbon unit productions --------------------------- infest the planet. PB al 12" G4 750 MB ram OSX 10.3.1 Digi 002R PTLE 6.2.2 |
Search this forum for 'power harness'. Contact Digidesign.
This is a very common problem on 002 and 002R, and in my opinion, they really botched it.
Quad 2.5 G5, 4.5G RAM |
Thank you Dave,
I called Digi support, and even though the warranty period was over, they sent me the harness (wire) right away. I have replaced the cable, and it has resolved the issue. Thank you for your advice, I was really getting woried. Syed |
Thank you tele_player,
Your were right, it was the harness. I called Digi support, they sent me the harness (wire) right away, I have replaced the cable, and it has resolved the issue. Syed |
Logic 8.0.2, Digi002r & Snow Leopard. Major issue: some ADAT Output don't work | mnstudio | General Discussion | 0 | 01-23-2010 11:28 AM |
waves issue when booting PT8 | djsin421 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2009 03:25 PM |
digi001 to digi002R upgrade playback engine issue | mytinycircus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-12-2005 04:02 PM |
digi002R I/o issue | musicmixer04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-31-2004 06:48 AM |
booting with xp | mooda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-11-2002 08:39 PM |
