Old 02-27-2003, 12:06 AM
307 307 is offline
Default Pencil tools
Hi
I'm using a 2.4g cup , 1 G ram pc with the protools LE but I can't use the pencil tools , did anyone knows whats happening?
Thanks a lot
Old 02-27-2003, 12:58 AM
Rail Jon Rogut Rail Jon Rogut is offline
Default Re: Pencil tools
You can only use the pencil tool when you're zoomed in pretty far..
Note that the pencil tool is destructive,.. If you want to draw a change you may want to first consolidate around the aea first.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-27-2003, 01:21 AM
307 307 is offline
Dear rail
I have try zoom in , zoom out all the way but still can't use the pencil tools .
Thanks
Dennis
Old 02-27-2003, 01:58 AM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Pencil is "NOT" destructive. I have used it many times an then hit "undo" because I didn't like the result. Maybe there is an option somewhere to make it non or destructive. Hmmmmm
Old 02-27-2003, 02:05 AM
Try searching the "answerbase" 307. I just looked in Pro Tools to see if there was an option to turn pencil on or off and there isn't. As far as I know it should just work. You have to be really far in (to where the wave form is just a wavy line) and then click the pencil buttin then click and drag on the wave form to pencil edit it. Good luck:)
Old 02-27-2003, 02:08 AM
Bastiaan Bastiaan is offline
If you are using the pencil it is indeed destructable. But you still have your undo's. But this is one of the actions in protools that actually happens to the original file, unlike stuff like crossfading, chopping off some stuff, audiosuite etc.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-27-2003, 05:14 AM
da BaSsTaRd! da BaSsTaRd! is offline
<font size="2" face="Verdana, Arial">hehehe... see what happens after you save... [img]images/icons/cool.gif[/img]
i love my apple iPhone!
Old 02-27-2003, 09:37 AM
Henning Z. Mortensen Henning Z. Mortensen is offline
Originally posted by 307:
Hi
Thanks a lot
<font size="2" face="Verdana, Arial">Set the Paging File Initial Size to 1065 or lower in Virtual Memory. 1024 is the recommended value.
To set this, go to:
SystemProperties>Advanced>Performance>Settings>Adv anced>Virtual Memory>Change
Or remove some of your RAM, so you have less than 1GB
I changed my paging file min and max to 1024, and it worked (on a TDM system)
Old 02-27-2003, 09:45 AM
mlemos mlemos is offline
If you have too much memory you can't use the pencil tool? [img]images/icons/confused.gif[/img]
Old 02-27-2003, 10:28 AM
<font size="2" face="Verdana, Arial">From Digi's answerbase:
"Regardless of my zoom level or session length, I have lost the functionality of my Pencil Tool.
This error was seen in systems containing 1GB RAM. Reducing the amount of RAM to 512MB resolved the error. "
Changing the paging file size worked for me. Didn't wanna reduce my amount of RAM. That was the most stupid solution i've ever heard from Digi!
Pro Tools 7.3 pencil tool not working wth? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2012 05:19 PM
Pro Tools 10 Pencil / Audtion issues BroomPole Post - Surround - Video 4 03-20-2012 08:01 PM
my Pro Tools 7.3 LE pencil tool stopped working GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-11-2011 04:58 AM
smart tools & pencil menus won't appear klickyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2007 09:40 PM
locked pencil tools dubC Pro Tools TDM Systems (Mac) 2 04-15-2003 08:43 AM
