Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 03-18-2022, 01:06 PM
Jeff Schmidt Jeff Schmidt is offline
Default MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s
I trying to route a few different sources from MTRX over Dante to a single input set on the MC 16 Trinnov.
Then send the Optimized output from the MC16 back to the MTRX over Dante and assign that to a DA output to the monitors.
The goal is to be able to switch sources going into the Trinnov via DadMan/MOM controller rather than the Trinnov UI.
I can't seem to figure out how to stick the Trinnov in between the SOURCES and an OUTPUT in DadMan over Dante. Is this possible?
2024 MacStudio M2 Ultra 192 GB RAM
Sonoma 14.4
PT ultimate 2024.3.1
MTRX STUDIO
Old System:
MAC PRO 7.1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate 2022.6
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
Old 03-18-2022, 01:12 PM
uptheoctave uptheoctave is offline
Default Re: MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s
Pretty sure that you need to do the routing in Dante controller.
In the MTRX send 16 outputs from Digilink to Dante 1-16 transmit.
Connect MTRX Dante transmit channels in Dante controller to MC16 Receive 1-16.
Then connect MC16 Transmit Channels to MTRX Dante Receive channels.
Then route the Outputs to your speakers (analogue or digital).
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest article: Multichannel Monitoring with Avid MTRX II
Old 03-18-2022, 01:21 PM
Thanks - unless I misunderstand - that suggested routing works only for a single source - the 16 Digilink channels in your example. I have 4 sources I'd like to send to the Trinnov (3 x 9.1.4 and 1x Stereo)
I'd like to use the MOM Controller to switch between the 4 Source sets going to the Trinnov.
Sonoma 14.4
MTRX STUDIO
Old System:
MAC PRO 7.1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate 2022.6
Old 03-18-2022, 01:33 PM
LDS LDS is offline
One way to do it would be -
Define your sources in DADman,.
Define a monitor outputs for the 16 channels of dante to your trinnov. You will then need to route your MTRX transmit channels to your trinnov receive channels in dante controller.
In dante controller you can then route 16 channels of trinnov transmit to MTRX receive for the returns back from your trinnov.
Then back in the DADman routing matrix, you can route the appropriate 16 dante input channels to the appropriate analogue outputs to your monitors. Basically just using your MRTX for dante to analogue format conversion.
This will put the DADman monitor section before your trinnov. DADman really needs an insert section in monitor profiles. A place between source selections and monitor outputs to stick things like room processing.
Pro Tools Ultimate 2024.6. OSX 13.6.6. Win 10. Avid Carbon. Lynx AES16e. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 03-18-2022, 02:21 PM
100% THIS.
This setup works - the key was I needed to remove the original 9.1.4 Monitor output to the speakers. That lets me use the Output to send to the Trinnov and then direct patch in DadMan from Trinnov out to DA out - thank you!
Sonoma 14.4
MTRX STUDIO
Old System:
MAC PRO 7.1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate 2022.6
Dante SRC on MTRX Studio ViciousLullabyz Pro Tools | MTRX & MTRX Studio 4 02-04-2022 03:00 PM
MTRX Dante IO clintonHT Pro Tools HDX & HD Native Systems (Win) 2 10-13-2021 04:14 AM
S6 and MTRX monitoring - Trinnov Dante Insert? acacia Avid S4/S6 8 08-22-2021 02:31 PM
MTRX Studio using Dante only c-tone Pro Tools | MTRX & MTRX Studio 15 08-20-2021 02:00 PM
MTRX-> HDX or MTRX->Dante ArmyofLight Pro Tools | MTRX & MTRX Studio 34 04-08-2021 04:51 PM
