To DADman Users,
I should know this but what does the red triangle mean inside DADMan. Is it a non connection or routing issue how can I resolve it on a DigiLink Port 1. Regards |
Sync issue with digital connections. It says the MTRX and the digital connected device don’t have a clock sync.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
Oh and regarding how to solve: red triangle can mean 2 things: the device connected to the MTRX is turned off. Then just turn it on.
If your HDX / HD Native is powered on and connected to your computer and digilink is connected to the MTRX unit, you can solve it in the most bottom section in DADMan: first tab 'Sync' and then at the right column 'Adapt to' set to 'Digilink 1' . That way when you open pro tools sessions at different sample rates, HDX / HD Native will be clocked to the PT session sample rate and the MTRX automatically locks to the sample rate of HDX / HD native e.g. your Pro Tools sessions sample rate.
Hi RobertDorn,
I think it could be related to power as the Native Thunderbolt HD is not showing a red light on the front maybe because I have power going to it through a usb 3.0 hub and not directly of my Mac. The sync settings in DADMan are Synchronization Sync source internal Sync out word clock Sync term HZ Digi delay (smplls) 7 Sampling Sample rate 48KHz Adapt to Internal (should this be DigiLink1)?. Regards |
![]() Quote:
Hi, Just a thought.. Did you install a new driver and not allow the install in security and privacy.. Been there and done that once-:) Last install I had to install the HD Driver twice for it to take for some reason. Then restart the computer. G
Composer/Sound Designer/Protools 2024.10.1 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Sonoma 14.7.5, DP 11.3.4, Logic Pro X 11.1.2 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
![]() Quote:
As for your DADman settings, please select ‘adapt to Digilink’ to ensure you will have a stable clock between your MTRX and your HD native interface at whichever Pro Tools session sample rate.
![]() Quote:
I wizzed thru the post here and did not see that was what he did Has to be USB-C for Thunderbolt to work. G
OT: Speaker Triangle | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-30-2008 04:50 PM |
little triangle | jpbm | Pro Tools TDM Systems (Mac) | 1 | 02-20-2005 03:23 PM |
What is this little triangle in my edit window?? | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-17-2004 04:41 PM |
Small triangle in waveform | Dopamine | Pro Tools TDM Systems (Mac) | 3 | 12-18-2002 12:55 AM |
Weird triangle wave artifacts??? | littledog | Pro Tools TDM Systems (Mac) | 5 | 04-25-2002 04:21 PM |
