Inactive-->Active midi; notes turned green & won't play
I made some midi tracks inactive, and then made them active again. After making them active again, the notes in the midi edit window turned green (they are normally blue) and don't create any sound, nor do they register on the meter as the playback bar moves across them. Any help would be appreciated--I'm in PT LE 8 Windows. |
Re: Inactive-->Active midi; notes turned green & won't play
Sometimes, when midi tracks are made inactive, then made active again, you must verify that the original routing is same as before.
Check midi in and out, are they greyed out? Was this a VI or external module generating sound?
PT11, Windows 10 RME Babyface
This was Xpand2. Though I didn't figure out the root cause, I just duplicated the track & the dupe works fine.
Thanks for the reply! |
Good!
VIEW -> MIX WINDOW->SHOW INSTRUMENTS
When you activate and deactivate Inst. Trax they will sometimes lose their assignments.
Sign up for all things....AWESOME! Kris May the music move you |
1st notes in midi will not play | LLRH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-12-2012 03:45 PM |
first MIDI notes won't play | levelaudio | MIDI | 6 | 03-20-2008 12:49 AM |
active/inactive plugins | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-19-2006 05:23 PM |
Midi notes turned black, won't play | choppervon | MIDI | 0 | 10-16-2006 05:30 PM |
transport record button has turned green! | nigel smith | Pro Tools TDM Systems (Mac) | 7 | 05-22-2005 03:22 PM |
