Old 07-10-2006, 12:18 PM
audiowiz audiowiz is offline
Default 002r not in Sound Preferences
I lost my manual, can someone tell me what the red lighted button above the 1394 button means?
Also, just today I've noticed the 002r isn't showing in the Sound Output/Input preferences panel. I'm on 10.4.7.
Any recommendations on how to trouble shoot this? I installed the 7.0 stand alone core audio driver and restarted....
thanks
Old 07-10-2006, 12:39 PM
onlyone-jc onlyone-jc is offline
Default Re: 002r not in Sound Preferences
Above the 1394 indicator? 'Mute', it says on the front of the unit. It's to mute the output to the main speakers (outputs 1+2).
onlyone-jc.
Old 07-10-2006, 12:44 PM
Thanks I see it says mute but when pushing it, nothing changes. And OS X.4.7 isn't seeing the 002r in the sound preference pane. It says it's not connected, HW not found, but it's connected...
Old 07-10-2006, 02:13 PM
I actually get that with my 002R too (using 10.4.2), but mine works just fine. It shows as 'Digidesign MBox 2' in the 'System Preferences' panel, for some strange reason. But, I've heard that's normal (not sure why). When I select it, I get this:
http://img54.imageshack.us/img54/5523/sc1ou.png
It seems odd that it can't connect, but hey, it works. I guess it's just one of those odd things.
Old 07-10-2006, 02:36 PM
turns out it's my damned power harness. this p.o.s.
I tried removing and reattaching the power harness wires a few times, nothing. Punched the damned thing, and it works again.
Old 07-10-2006, 02:47 PM
Haha! Generally does the trick!
onlyone-jc.
Old 07-11-2006, 08:15 AM
I know you've solved your problem now, but, do you, or anyone else for that matter, get why my 002R won't connect in the 'System Preferences' panel? It seems a bit odd, but I've never really questioned it until now, since the unit seems to work okay, albeit a few hardware drop-outs every now and again.
Is it a firmware issue, maybe?
Thanks,
onlyone-jc.
Old 07-11-2006, 09:34 AM
DigiTechSupt's Avatar
This is because the Mbox2 control panel is installed by Pro Tools by default. If you don't have an Mbox2 connected to the computer, it won't show connected in the Mbox2 control panel. You can remove the Mbox2 control panel by deleting it from MacHD>Library>PreferencePanes.
Avid Audio Tech Support
Support FAQ
Old 07-11-2006, 09:47 AM
Right-o!
Thanks Digi,
onlyone-jc.
mac system preferences shows mbox2 fiirmware instead of 002R muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-04-2007 08:15 PM
mac system preferences shows mbox2 fiirmware instead of 002R muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2007 07:49 PM
Mac is Not Seeing 192 in Sound Preferences dmtny Pro Tools TDM Systems (Mac) 0 11-19-2006 10:14 AM
mbox in sound preferences won't go away 8trackmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-08-2005 03:49 PM
9600 sound preferences with others soundboy35 Pro Tools TDM Systems (Mac) 0 10-25-2002 02:47 PM
