Will RealPlayer .ram files play in anything else?
I hate RealPlayer, and don't want to install it, but there's plenty of sites that use it.
Re: Will RealPlayer .ram files play in anything el
hi mr. seaman, i don´t know in PC buit in MAC it works nice
, it´s only a player, i like it best than the VLC thing. so, did you bought the WC for your boat? the big one?
so what |
on mac:
in quick time, no in itunes,no couldn't import in peak4, in live it didn't even show, in vlc, it looks like it was going to open, but, gave message: unable to determine stream type. anyway none of them have .rm files as an option to open nor import. cheers sailor.
so what |
i have this program called SoundConverter,
that does convert to or from .rm files, though it's only for mac this is the one and it's pretty cheap.
so what |
I'm PC based.
The last time I tried RealPlayer it insisted on having access to the internet, changing my file associations, and doing all kinds of stuff I didn't like or understand (which I didn't like either). WMP is prone to do that too. I only use WMP when I'm disconnected. VLC on the other hand simply opens and either plays your file (most of them) or doesn't. It doesn't set about doing other things - like making net connections - cos some twit programmer thinks it's clever to take over your system. I prefer VLC. There must be players that will just play RealPlayer files without messing with your system like it does. You won't find any commercial players doing it because of licensing reasons. |
Karel,
RealPlayer should have a list of file types under Options/Preferences. There you can disable any file types other than .ram files, so it will open play those.
rh music |
Follow my link above and you'll see that there's more to it than that.
It's a video nasty. |
There's something called the "Real alternative". I have it installed, but forgot where i got it....
loked it up : http://home.hccnet.nl/h.edskes/finalbuilds.htm
What's that? - That's the machine that goes "pling". Bastiaan |
Error -6097 after RealPlayer installed | mark14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-23-2009 09:37 PM |
Realplayer 10 and Coreaudio? | Arno Peeters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-16-2005 07:06 AM |
HELP: Wav is converting to RealPlayer! | quadra605 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-22-2003 06:05 PM |
Realplayer Export problem | John H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-08-2002 02:04 PM |
ANYONE USING REALPLAYER? | naman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-05-2001 10:18 PM |
