How to sync Protools with Nuendo.
Is there anyway to midi chase Nuendo to Protools without using midi cables? What I want to do is emulate the midi connection internaly so I can sequence my soft synths in Nuendo and send the outputs via lightpipe to Protools.
Jayman #9 |
Re: How to sync Protools with Nuendo.
I think you'll have to use midi cables.
Use MTC from Nuendo to trigger playback of PT. Also get PT to lock to word clock from Nuendo. This will be your most reliable setup. If you use MTC trigger from PT I don't know if Nuendo will continue to follow as PT MTC is not continuous (triggers GO then nothing). Might work if you can tell Nuendo to free wheel if incoming MTC stops. Don't forget the word clock ... it's the only thing that will keep you in sync. Oz |
protools does detect start and stop through MTC.
Maybe you ca run the combo without cables if you use HUBI's loopbackdevice or midiyoke (these are virtual midicables). To have both programs locked, feed spdif from the slave to the master. Make sure you run both sessions on the same samplefreq, and the same framerate in MTC...
What's that? - That's the machine that goes "pling". Bastiaan |
[img]images/icons/smile.gif[/img]
Jayman #9 |
i love my apple iPhone! |
help with hd 7.4 - nuendo mtc sync problem | peeweedrummer | Pro Tools TDM Systems (Mac) | 3 | 07-09-2009 11:34 AM |
Protools AAF to Nuendo | gerbilate | Post - Surround - Video | 2 | 06-30-2005 08:46 AM |
Sync issues....PT and Nuendo | elementsound | Pro Tools TDM Systems (Mac) | 1 | 09-06-2004 01:29 AM |
ProTools V/S NUendo | Benyvin | Pro Tools TDM Systems (Mac) | 31 | 09-16-2003 04:42 PM |
Nuendo and Protools | lil big | General Discussion | 4 | 04-24-2003 09:14 PM |
