Old 04-27-2022, 08:50 AM
Emi's Avatar
Emi Emi is offline
Default Black square dot on aux track [PT-285434]
What´s the black square dot next to the aux track vu meter?
It appeared when I upgraded to 2022.4
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 04-27-2022, 01:05 PM
Default Re: Black square dot on aux track
Originally Posted by Emi View Post
What´s the balck square dot next to the aux track vu meter?
No black dots here on Studio 2022.4 on Big Sur. Well except for the standard clip indicator above the meter, has that moved location for you?
This only happens for VU type meters? Only on Aux tracks? Mono? Stereo?
Post a screenshot.
What shows up with no plugins on that aux? (in case it's an artifact of a gain reduction meter, some problem interaction with a plugin etc.).
Old 04-28-2022, 07:54 AM
Emi's Avatar
Emi Emi is offline
Hi Darryl,
Doesn´t matter if it has plugins or not, I don´t have reduction metter activated on the aux channel, but it doesn´t matter, the dot it´s still there.
It happends on all type of meters, but only on Aux tracks (mono, stereo...5.1)
It´s not the clip indicator. See attached images.
Thanks,
Old 04-28-2022, 08:16 AM
BScout BScout is offline
On the Mix window definitely looks like a glitch. If you take it out of dark mode, does it go away?
On the Edit window, it looks like where the playlist selector would be. Of course Aux tracks don't have playlists. I'd ask if this is tied to dark mode again.
What are your system specs (computer version and operating system)? And what screen resolution are you at (and if using a high pixel display, are you using scaling from the operating system to make things bigger)?
(Should mention, I don't see this in my sessions but I don't use Dark Mode which has had its graphical issues and I don't use scaling in macOS)
Old 04-28-2022, 08:33 AM
Emi's Avatar
Emi Emi is offline
Still there on dark mode.
System specs: Mac mini M1, 16 Gigs of Ram, Monterey 12.3.1
Screen resolution: Default 2560 x 1440
I don´t use dark mode, and nither scalling in macOS. All default.
It appeared on Pro Tools Studio 2022.4
Thanks,
Old 04-28-2022, 08:56 AM
diamondschwin diamondschwin is offline
I have it too.
Mac Studio Ultra, Pro Tools Ultimate 2022.4, macOS 12.3
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
Old 04-28-2022, 11:13 AM
Both Monterey and both M1 (which means same graphics engine since all the M1 chips use the same GPU just different number of cores.)
I don't have these issues (But not on M1/Monterey)
They did some graphics improvements to improve responsiveness on this latest Pro Tools. I wonder if they used some Metal GUI framework component for that area (maybe to render "peak/clip" which is about that spot) that isn't playing well or scaling with the rest of the graphics. Hopefully other M1 users will chime in (I'd be more interested if there are M1+macOS Monterey users without the problem to figure out if that's the root issue so Avid can recreate for fixing.)
Last edited by BScout; 04-28-2022 at 12:19 PM. Reason: clarification of what "it" meant
Old 04-28-2022, 12:11 PM
Emi's Avatar
Emi Emi is offline
And another graphic issue,
when using takes, and change back to waveform on the track, a giant black line appears (see attached picture). It goes away when you change track hight.
Old 04-28-2022, 01:01 PM
jeffro's Avatar
jeffro jeffro is offline
Not seeing this here, but I'm on a 2019 iMac w/Catalina currently. In your screenshots it looks oddly similar in size (but shifted over slightly) to the MIDI and Signal Indicators on Folder Tracks.
linkedin
Old 04-28-2022, 01:36 PM
zoff zoff is offline
Originally Posted by diamondschwin View Post
I have it too.
Me too, on Aux tracks.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Bug Video goes black when changing online track kosmokrator Post - Surround - Video 2 05-31-2021 12:58 PM
Video track in black when played back Marcomarin Pro Tools 11 5 04-24-2018 04:06 AM
There's A Surround Panner and It's Square!! alk3997 Avid S1, S3, Dock and Control App 1 05-17-2016 06:45 AM
uhh...why is my instrument track black & gold? sykobilly65 Pro Tools M-Powered (Mac) 1 08-28-2008 07:55 PM
Flakey behavior / System Resources red square? Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-11-2007 04:25 PM
