Could use some advice as I'm a bit new to clocking outside of standard Avid Loop Sync.
I have 3 Avid 16x16 HDIOs and 1 Avid Digital HDIO. I currently have the Digital HDIO as the Master Clock and the other 3 in appropriate Loop Sync. Working fine. I am adding a Trinnov D-Mon 12 to the rig and will primarily feed it via 16 Ch. AES from the Digital HDIO. (It will also get some analog input from external summing, etc.) But not quite clear on best way to clock the Trinnov. Will it just get the clock via the AES and so I don't need any other connections? Or can I run word clock out of the Digital HDIO to feed the word clock in on the Trinnov? Or is this where I need to add a master clock, Sync HD/X, etc.? Appreciate any and all guidance here. Thx ----------------------------- David Redondo Beach, CA 2019 MacPro Rack 3.3 GHz 12-Core Intel Xeon W, 240GB Ram MACOS 11.6.1 Big Sur PT Ultimate 2021, HDX x2, UAD Octo x2 |
KISS
Let the monitor controller clock from AES/EBU, no need to do anything else beyond how you are using loops sync now. You could connect word clock out of an Avid box into the monitor controller, up to you, but I'll eat my hat if you hear any difference. Absolutely no need to throw away money on a Sync HD... ya ain't slinging video etc. so you don't need or want one. |
Thanks! I was pretty sure I was over thinking it!
David Redondo Beach, CA ——————————- 2019 MacPro Rack 3.3 GHz 12-Core Intel Xeon W, 240GB Ram MACOS 11.6.1 Big Sur PT Ultimate 2021, HDX x2, UAD Octo x2 |
Sync HD reverts back to loop sync after PT quit | pqlior@mac.com | macOS | 1 | 07-23-2015 02:37 PM |
Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync | audiomark | Post - Surround - Video | 5 | 02-14-2013 03:09 PM |
Sync Audio - Editor Used Camera Track Only -Waveform Sync? | milosziv | Post - Surround - Video | 7 | 11-30-2011 05:26 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
