Old 05-24-2013, 07:09 PM
BasketCase BasketCase is offline
Default Protools HD Native card via coreaudio?
Hey guys,
Over the last few weeks I have been investigating my options for moving to PT11... not necessarily PT HD 11 though, from a HD system. Currently I use Apogee 16x converters - with no intention of changing, as they do the job nicely!
So far I am investigating:
- Apogees via RME AES card.
- Apogees via LYNX AES card.
- Apogees via RME RAYDAT
- Apogees via Apogee Symphony 64 card
- Apogees via HD Native card.
There seems to be some pretty clear advantages for going the Apogee Symphony 64 or HD Native route. The main one being that it allows the 16x converters to be used in advanced routing mode. This gives a 1x AD16x and 1x DA16x 64 channels of I/O (16 analogue in, 16 analogue out, 16 digital in, and 16 digital out) via one card. The Lynx or AES solutions won't do that...
So... summing up the prices to get those 64 channels of I/O:
RME - 2x RAYDAT or AES = $2000 to $3000.
LYNX - 2x AES = $1300.
Apogee Symphony with X-cards = $1400.
HD Native card = $1000 used on ebay.
So the HD native card at present is pretty cheap as well! But will it run under vanilla PT11 via core audio and offer the 64 channels of I/O I need? ...because PT HD software obviously isn't included when purchasing a cheap second hand HD native card.
Old 05-25-2013, 07:51 AM
nst7 nst7 is offline
Default Re: Protools HD Native card via coreaudio?
You will need an HD license for Protools to recognize the HD Native card, and thus anything that's hooked up to it.
Old 05-25-2013, 05:35 PM
so that is to say - there is no coreaudio drivers for the HD native card?
Old 05-26-2013, 05:49 AM
Yes, there is, but it won't work for Protools with the HD Native card (or Thunderbolt version). Just for other DAW's (Logic, Cubase, etc.).
Meaning, if there is an HD Native card (or Thunderbolt version) installed, with an HD (or 3rd party HD compatible) interface hooked up, it will need to see an HD license on your Ilok. If it doesn't see an HD license on the Ilok, it will make you choose a different interface, such as usb, firewire, built in computer output, etc., in order to use Protools.
Old 05-27-2013, 01:33 AM
Well that is a bit ridiculous... innit.
The HD native card works via coreaudio, so Avid put the time in to actually break that functionality within protools.
Old 05-27-2013, 06:29 AM
Brock Mixwell Brock Mixwell is offline
The avid core audio and asio drivers are absolutely shocking SHOCKING!
If your main priority is to run core audio/asio you would be stupid to put cash towards an hd native card.
These systems choke almost immediately at low latency, the Mbox series drivers are even worse.
If you are looking for a high performance core audio/asio solution you should get an rme hdsp card
The extra investment will more than pay for its self
(Words from an hd native owner who chooses to run pro tools under rme drivers for better stability (only holding the hd native card in case avid lock to hardware for hd 12))
Old 05-27-2013, 11:14 AM
Please don't spread misinformation just because you had trouble with your system.
Most people are doing with these systems exactly what you say can't be done.
Old 05-27-2013, 11:17 AM
@Basketcase,
Your best option would probably be to buy an HD Native/Omni bundle, and just sell the Omni. Or keep it if you need a monitor controller.
Old 05-27-2013, 12:54 PM
smfelton's Avatar
smfelton smfelton is offline
i'm sure i read somewhere that someone had tested it and Native HD Card did work with PT10 non HD obviously they had none of the HD software functionality but did work for i/o. I could be wrong. But it makes sense as the drivers are built in to the single installer. I don't have a non HD licence so i'm afraidI cant try this.....
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 05-27-2013, 02:37 PM
I believe it was a CPTK license in the situation you're referring to.
Is it free Protools 11 for native card as well? [email protected] Pro Tools 11 3 04-10-2013 12:36 PM
WTB: Native HD Card with Protools 10 SoundEng1 Buy & Sell 3 01-27-2013 11:23 PM
Protools can't/won't see my native card thephil Pro Tools HDX & HD Native Systems (Mac) 2 10-06-2011 01:27 PM
ProTools 9.0 and HD Native Card on OS 10.6.8 MGohil macOS 4 06-27-2011 10:52 PM
Native core card , & C8 /C24 , run Protools Ducati 996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-03-2004 09:31 PM
