Mastering tools
hi guys what do you recommend for tip top mastering do you use finalizer for instance or waves plugs etc please advise me as I am keen to get finalizer unless a software plugin does the job just as well and of course cheaper.
Thanks Guys [img]images/icons/smile.gif[/img] |
Re: Mastering tools
TC MASTER X! Period. 3 Band, 5 band, whatever! Get it. You won't be sorry.
Andy O. |
Re: Mastering tools
As far as i know, you can do anything in PT that you can in a finalizer ( EQ, multipand compression, limiting, expanding, dessing, dither )
Re: Mastering tools
I was a long time Finalizer addict, then I found frequencys I was EQ ing and copied the exact ones to a Waves plug in and A/B ed them. The waves was better, the Finalizer - was a little metalic in comparison.
[img]images/icons/smile.gif[/img] Jules |
Re: Mastering tools
Hi Taiazeez,
The Finalizer is only suited to some styles of music. Styles where over processed dynamics etc., is not a problem. Loud rock & pop etc.: its good ,but anything from country & beyond, the real musicians will complain about its qualities in an overwhelmingly negative regard !! Period!!! I've had to ditch it more than once on a gig even after a lot of tweaking. It was just the wrong box for the gig. (32 strings & 36 Big band) Try Waves C4 multi-band for a start. (most usable) Regards Michael [img]images/icons/shocked.gif[/img] |
Re: Mastering tools
Don't mean to confuse you...but I vote for TCMasterX and +L1 TOGETHER!
I use the 3-band TCMasterX and the +L1 and love the results.
One good thing about music: when it hits, you feel no pain. --Bob Marley Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.5.2 / PT 2023.9 / Waves Horizon v14 / iZotope Music Production Suite 4.1 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors |
Re: Mastering tools
I'm pretty fond of the L1+ in the waves bundle. The leveling is good, the sound is hot without being metallic and you've got some dithering options at your disposal. I have heard the TC master works plug-in and that's good also. [img]images/icons/wink.gif[/img]
Re: Mastering tools
.... But then again.... Finalizer has this pretty cool "digital radiance generator" thing. It adds something to your mix that makes it a bit "fatter". And sometimes it´s cool to have 3 band compressor after your preamp when you record...
But plugins rule anyway! I use separate PC for mastering...it goes thru finalizer for "radiance" and I process it afterwards with plugins...lots of undo´s possible [img]images/icons/smile.gif[/img] (Steinberg Mastering Edition makes miracles aswell as any Waves or TC plug) [ August 06, 2001: Message edited by: digidesigner ] |
Re: Mastering tools
Forget the Waves C4 and get the tc electronic M5000 w/MD2 option. It is obviously not a plug in but it is the best digital solution I have heard.
Re: Mastering tools
I've had a finalizer for a while but I've stopped using it in favour of focusrite plugins. I think as someone else mentioned that the finalizer is better on rock etc than on music with a greater dynamic. I'm sure my use of it is not as good as it could be, but I find that it seems to either ruin things by being over the top, or just does nothing.
Jack |
Pro Tools Mastering | Mvrphy | Pro Tools 9 | 13 | 10-01-2011 07:45 AM |
Mastering i Pro Tools HD | Inthebox | Pro Tools TDM Systems (Mac) | 6 | 10-16-2009 08:55 AM |
mastering in pro tools???? | sonny7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 02-12-2008 04:10 AM |
The TDM Mastering Tools | Magno | Pro Tools TDM Systems (Mac) | 0 | 10-08-2004 08:08 AM |
how is mastering done in pro tools le on a PC | gregoryb | General Discussion | 3 | 06-03-2002 06:01 PM |
